Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-09-2018, 06:05 AM
Raoul23 Raoul23 is offline
Default MacBook Pro 2010 Common GPU issue
I’m looking to buy a Mac book pro around the £400-£500 mark I keep hearing about the i7 2010 graphic issue, can anyone fill me in on what this issue is and if they have experienced it
Thanks in advance
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 02-09-2018, 06:47 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: MacBook Pro 2010 Common GPU issue
I just got a 2012 and I have seen no errors running PT12.4
I would recommend a 2012 because it has both Thunderbolt and FW800...they can also be had for the same amount of money
Daniel
Old 02-09-2018, 07:26 AM
When I say GPU issues I mean the board fails not issues the the graphics. Something about kernel panic
Also what speed i7 should I go for
Raoul Crane
Old 02-09-2018, 07:33 AM
YYR123's Avatar
The fastest you can, for the money you can afford
Daniel
Old 02-09-2018, 07:52 AM
Someone said I won’t notice that much difference between a 2.66 and 2.8
Wish I New more about this kernel panic issues, bit scared of buying 2nd hand and it needs a new board a week later
Raoul Crane
Old 02-09-2018, 08:07 AM
YYR123's Avatar
If it’s got to be stable buy a newer model.
Daniel
Old 02-09-2018, 08:34 AM
bcwiz's Avatar
bcwiz bcwiz is offline
The Macbook 2010 GPU kernel panic issue is commonly caused by a failed tantalum capacitor on a video power rail (frame buffer). The part costs $2 and takes about an hour to change. I have repaired two 2010 MBP with this problem. Back in the day Apple would replace the logic board and if out of warranty costs $750.
Anyway if that spooks you go for a 2012 as Daniel said in earlier post plus it has USB3.
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
Old 02-09-2018, 08:58 AM
What are the signs of this failing capacitor??
Raoul Crane
Old 02-09-2018, 09:01 AM
YYR123's Avatar
The GPU failing issue
Daniel
Old 02-09-2018, 09:03 AM
Lol 😂 would there be lines on the screen or any thing
Raoul Crane
SSHD or SSD for MacBook Pro 7,1 (mid 2010) 13" SpaceCarRider macOS 3 07-31-2015 01:27 AM
2010 MacBook Pro model and PT HD Native tritonkorg Pro Tools HDX & HD Native Systems (Mac) 18 08-08-2014 06:05 PM
PT9 on 2010 11" Macbook Air - which interface? mds1001 macOS 1 08-22-2011 01:15 PM
PT9 with Macbook Air 2010 and Apogee One producerdna Pro Tools 9 20 06-17-2011 03:37 PM
Macbook pro (mid 2010) 15” 2.4 / i5 is getting too hot! PetrosGls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-10-2011 02:17 AM
