Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-19-2017, 04:12 AM
Default Re: Monitors upright or on their sides??
Originally Posted by albee1952 View Post
Looking at the Yamaha's, the waveguide appears to be conical, so it should be okay with the speakers on their sides, but it will likely narrow the "sweet spot"(would not be my "ideal" configuration). Experiment with both positions and see if you hear the sweet spot shrink(or am I deluded)
I would be more worried about reflections off of any console or other surface right in front of the speakers. I don't have the HS8's but do have the MSP5's and the sweet spot for frequencies coming from the tweeter does change a little. Don't know much of a difference it makes in dispersion but the MSP5's are front ported.
Jack
QAPLA!
Old 09-19-2017, 05:13 AM
Drew Mazurek's Avatar
Originally Posted by Raoul23 View Post
That's the thing the desk that is being made will either allow upright or on the side but I need to decide which one before it's made
I recommend NOT having the speaker stands be a part of the desk. It's WAY too limiting. And will likely make the monitors too close to you. And what if you change speakers? I can almost guarantee you'll regret it.
I have all my speakers on separate stands. The Barefoots are custom made for them, but the NS10s and JBLs are on inexpensive store bought ones.
More pics here. https://www.facebook.com/Drew-Mazure...?ref=bookmarks
www.drewmazurek.com
Old 09-19-2017, 05:49 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Originally Posted by musicman691 View Post
It depends on the monitor design. There are some out there that are specified to only work as designed in the upright position. Yet others have a specific right and left position. Really have to dig into the documentation that comes with the monitors.
Or just get a pair of Horrortones and there isn't any upright or on the side
Interesting! I just found a pdf file online for my Alesis Monitor Twos, and it turns out I have had them set up wrong for years. The tweeter sits between the woofer and the mid-range, about 2/3 the way up from the bottom. Depending on which speaker you are looking at, the tweeter is either on the far left or far right side of the speaker, about 3 inches from the side. I had my speakers positioned so that the tweeters on each speaker were on the "outside" of each speaker. They should be on the "inside" of each speaker when facing the speakers, in other words, the tweeters should be closer to each other rather than farther apart. Alesis could have made set up easier by labeling the speakers left and right, but instead they labeled them A and B.
I doubt whether my poor mixing skills will be impacted by swapping the speaker positions, but at least now I have them positioned correctly.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 09-19-2017, 06:46 AM
amagras amagras is offline
You have a beautiful studio Drew!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 09-19-2017, 09:10 AM
Raoul23 Raoul23 is offline
Drew that is the kind of set up I'm going for
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
  #16
Old 09-19-2017, 09:44 AM
Thanks!!!
www.drewmazurek.com
  #17
Old 09-19-2017, 09:45 AM
then don't put your speakers on your desk!!
www.drewmazurek.com
  #18
Old 09-19-2017, 11:38 AM
YYR123's Avatar
YYR123 YYR123 is offline
What size screen do you use?
I've wanted to go bigger than my 27" for awhile but was concerned about my monitors being too close to each other.
Daniel
  #19
Old 09-19-2017, 11:57 AM
Daniel: Check your speaker's manual. Mine says the speakers should be no closer together than 60" (center to center) and the sweet spot for the user to sit would be 60" from each speaker. To widen the sweet spot if 2 people are listening, the speakers should be angled less toward the center.
  #20
Old 09-19-2017, 12:01 PM
YYR123's Avatar
Good deal, sounds like a plan
Daniel
Best way to mic an upright bass... kchandlermusic Tips & Tricks 6 09-09-2014 12:52 PM
mic for upright bass? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-28-2005 10:29 PM
The two sides of the (VST) coin Stiff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-12-2003 04:35 AM
Drives on both sides of 2940UW? Steve Garman Pro Tools TDM Systems (Mac) 10 05-08-2001 09:00 AM
