2 ProTools versions on same computer?
I have a G4 tower and an ibook that both allow you to boot into either OSX or OS 9.2. For a variety of reasons there are times I want to use an older non-OSX compatible ProTools version (with all those non OSX plugs I have) and other times I have to have the features only available with OSX and 6.1. Can I boot into OS 9.2 and install ProTools 5.whatever and then boot into OSX and install ProTools 6.1 without any conflicts, so that I can use either version with the same Mix hardware? I have a similar plan with the dual OS ibook. On the road I'll be using an Mbox that I'll sometimes want to use with the OS 9.2 version of ProTools LE that will work with a ton of non OSX RTAS plugs I have and other times I'll want to use the 6.1 version for the ReWire implementation only available in 6.1. Any problem installing both versions of the Mbox ProTools LE software in the same ibook?
Thanks |
Re: 2 ProTools versions on same computer?
no problem in either case, go for it.
Thanks. I've already ordered both computers 'cause I need em anyway, but it's great to know that the wild idea of 2 operating systems running different ProTools versions with different plug-in assortments in the same computer will work. Being able to go back and forth from one operating system to the other so easily and all ProTool sessions being so platform and operating system independent is really convenient. In my case I've even got the additional complexity of using a 2.4 Ghz PC for sessions involving huge CPU demands, like lots of edit changes and plugs and lots of Propellerhead stuff with ProTools at the same time (using Re-wire). Will things ever stabilize enough so that one computer will have the same OS long enough so that one system will do everything without constantly spending a fortune upgrading? Lucky that Mac has this dual OS option on some of their computers.
Can 1 computer have 2 versions? | TTMJP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-13-2009 11:56 PM |
how to install 2 different versions of protools on one computer? | djkaz | Pro Tools TDM Systems (Mac) | 7 | 06-27-2009 01:36 AM |
how to install 2 different versions of protools on one computer? | djkaz | Pro Tools M-Powered (Mac) | 5 | 06-26-2009 11:14 PM |
multiple versions of ProTools on one computer? | KingTor | Pro Tools TDM Systems (Mac) | 4 | 09-15-2006 12:01 PM |
possible to have 2 PT versions on 1 computer? | Mike F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-17-2006 04:47 PM |
