Old 02-04-2020, 01:16 PM
michael c michael c is offline
Default A couple of bugs in Ultimate HD 2019.12
I've been using PT HD since 1998 so I know the program very well...
Today I was doing music on a commercial and when i tried to import some of my personal samples which I always use (cymbal hits, rolls with mallets, percussion hits etc.) PT would not let me import them, they were greyed out but other files in the same category were just fine. These are files that were created at the same time or even later and have ALWAYs worked and it is just random files. I tried to then import them through Workspace but that didn't work either. They are .wav files. I WAS able to import them if I went to a previous song or cue and imported them from the audio file folder in that cue.
The other thing I had several issues with was that PT stopped playing and I got the video error that I rarely if ever have gotten. The video was QT MP4. MPEG-4 AVC. I always get these and never had issues. It's just a :30 second spot.. If I hit play 3 or 4 times the video played fine and this was also random. Not always.
Are these known bugs or is this only me?
Thanks for any help.
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.6.8
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.6
HD Native Thunderbolt
Old 02-04-2020, 02:09 PM
BScout BScout is offline
Default Re: A couple of bugs in Ultimate HD 2019.12
Move up from Sierra (even to High Sierra) -- there have been issues noted with Sierra starting with all the 2019 versions of Pro Tools.
Check file permissions on those files you were trying to import. It sounds like they may not be accessible due to file permissions.
Old 02-04-2020, 02:20 PM
bartosz idzi bartosz idzi is offline
This. I started to have issues with Sierra and 2019.6 i think, then moved to Mojave and all is good.
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
Old 02-05-2020, 07:01 AM
I checked permissions and they are just fine, so it's not that. I don't think I get can High Sierra anymore and not sure if some other software we use works with Mojave? That might be okay IF I can still get Mojave?
Thanks.
Monterey 12.6.8
64 GB RAM
Old 02-05-2020, 07:33 AM
TNM TNM is offline
High Sierra:
https://support.apple.com/en-au/HT208969
Mojave:
https://support.apple.com/en-us/HT210190
Enjoy :)
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 02-05-2020, 07:36 AM
JFreak's Avatar
JFreak JFreak is offline
Sierra is not supported any longer
Janne
Old 02-05-2020, 01:04 PM
Originally Posted by TNM View Post
Thanks for this.
Still confused why some of my files load in and some won't. It appears arbitrary. Files that I recorded in the same day a few years ago, one loads in and one doesn't and they are on the same drive.
Thanks for any other thoughts on this.
Monterey 12.6.8
64 GB RAM
Old 02-06-2020, 04:51 AM
thierryd thierryd is offline
Originally Posted by michael c View Post
The video was QT MP4. MPEG-4 AVC. I always get these and never had issues. It's just a :30 second spot...
mp4 video is a big no no in PT. You should always convert the video to something less procesdor taxing: Avid DNxHD36 and Apple ProResProxy or LT are good options.
Greetings,
Thierry
http://www.a-sound.com/
Old 02-06-2020, 06:52 AM
One more thing that is VERY odd is that now some of the files that will NOW work in ProTools have had their names changed. I haven't renamed them. These are files that are 4 to 15 years old and on a separate drive.
They are listed as .L.L.wav and .L.R.wav These will now load into ProTools. But the original files (cymbal hits) won't load into PT even though they ALWAYS have loaded in to PT. They are in previous PT sessions created in the last 4 years. Other .wav files created at the same time as these renamed files will work in PT and so will others created at the same time. Others WON'T work in ProTools.
Not sure if this is a PT issue since these files are on a separate drive and not our system drive?
Any thoughts on this?
Monterey 12.6.8
64 GB RAM
Old 02-06-2020, 01:41 PM
capt kirk capt kirk is offline
ooo boy, stuff like that scares the sh't outta me.....thats why i got physical separated backups
www.kfaudio.ca
2019.5 Ultimate on a Mac Pro 5,1 DenverAudioGuy Pro Tools 2019 44 05-28-2019 03:25 AM
A couple bugs ergalthema Pro Tools 11 1 08-18-2014 10:39 PM
A couple of PT8 interface bugs meech Pro Tools TDM Systems (Mac) 2 09-05-2009 07:25 PM
A couple of PT7 CS5 Bugs DAS-Mike Pro Tools TDM Systems (Mac) 1 03-26-2006 11:39 AM
