Audiosuite Rendering Problem
Hi there
I'm running 11.1.2 on a Macbook Pro with OSX Mavericks installed. When I used to render files using Audiosuite plugins in PT8, an entirely new audio WAV file would be created in the Audio Files folder of my session. Now, when I render, a new file is NOT created in Pro Tools, instead it appears that merely a new region in the clip list, complete with adjustable handle times for dragging back out etc is now available. But I need the whole rendered files! Is it possible to switch this function back on? I suppose it's the same as offline bouncing, but I don't want to go through having to offline bounce everything with the effect on an insert. Any clues? There's nothing in the Preferences that I can see... Thanks Phil |
Re: Audiosuite Rendering Problem
Prefs/Processing/WholeFile.
Might need to also set the handles to 0 |
Yep - I just needed to reduce the Handle time to 0 and it creates a new WAV file.
X form rendering problem | brady_d79 | Pro Tools 10 | 0 | 10-21-2013 07:33 PM |
why is audiosuite rendering to region list and not to edit window?? | luts | macOS | 1 | 06-28-2012 12:21 AM |
OLD PT New Problem with Audiosuite | Lowdbrent | Pro Tools TDM Systems (Mac) | 2 | 05-25-2009 04:57 PM |
audiosuite plug ins problem ...arrrggg audiosuite | hotcarl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-23-2004 02:35 PM |
