Old 10-17-2012, 10:24 PM
ratava911 ratava911 is offline
Default Click track not lining up to grid.. any thoughts?
My band is recording. Engineer is using logic and a Tama Rhythm Watch for the drummers click.
He bounces me down a wav of the click track the drummer used to track
I imported the track into a pro tools session set to same bit/sample rate. I set to the tempo he mentioned and i find that his click track is gradually slowing down. It matches the grid in pro tools in the beginning but by the end of the song, the grid and the click track differ by almost a 16th note.
Is it possible that the Tama Rhythm watch is just not consistent? or is there something I'm not thinking of that's causing this.
Old 10-17-2012, 11:20 PM
Default Re: Click track not lining up to grid.. any thoughts?
What makes you think the Tama Rhythm watch would be accurate enough? Does it line up on a grid in Logic?
But really ideally you want to get whatever is providing the click synced to the clocking source being used. i.e. you want to generate a click track from within Logic.
Or if you've got this and the click seems consistent and just off a tiny bit you can just use elastic audio to fix it up.
Darryl
Old 10-18-2012, 05:38 AM
Ben Jenssen's Avatar
Or adjust the sessions tempo.
It can be set very presisely, like 120.001 bpm.
Sync Grid Lines To Click Track nickacuff1289 Pro Tools M-Powered (Win) 3 02-16-2012 04:13 PM
Grid Not Matching Recorded Click Track Jmel58 Pro Tools 10 12 12-25-2011 10:04 AM
How do turn a click track inti a grid centerstage Tips & Tricks 2 04-23-2005 10:23 AM
Click track and grid edit Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-06-2004 07:49 AM
click track and Grid mode, help ! glockopops Tips & Tricks 3 01-19-2003 09:44 PM
