Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-29-2020, 02:03 PM
itsjustmeee123 itsjustmeee123 is offline
Default Yet another midi issue....
For some reason, my midi volume seems to jump from wherever I set it to close to 0 within Native Instruments VIs. I don't even have to be playing it. I can have Komplete loaded and sit here watching the volume fader and it will just randomly jump down with no keys pressed or the session playing. This has to be a Pro Tools 2020 issue. It doesn't seen to happen with other VI plugins like Play or the UVI Workstation ... only the NI stuff. And just to double check, I loaded Kontakt 6 standalone without Pro Tools and the volume works fine.
Any thoughts or suggestions would be greatly appreciated.
Update .... all fixed.
Old 04-29-2020, 06:01 PM
john1192 john1192 is offline
Default Re: Yet another midi issue....
was it a Blip of Automation at the beginning of all or some of your tracks ???
curious what it was, but respect if you do not wish to share .. silence will say that !!
cheers and happy you got your issue resolved
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 04-29-2020, 07:19 PM
It was actually another midi device sending a volume control command. When I initially set up my new iMac with PT 2019 a few months ago, I just had everything checked in the Midi Input Enable setting which included Euphonix ports 1 through 4 and a Line 6 Helix as well as my Arturia KeyLab 88 controller. It worked fine up until a few days ago. I tried everything and then just by luck I unchecked the other devices other than the Arturia and that fixed it. I'm not sure why it only affected Native Instrument VI's only.
Old 04-29-2020, 08:30 PM
thx for the info !!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
MIDI problem - Midi Studio Issue Microphone33 MIDI 4 02-27-2016 11:49 AM
MIDI problem - Midi Studio Issue Microphone33 Virtual Instruments 0 02-07-2016 02:09 PM
midi issue- can see midi signal but cant's control Xpand2 macroniche Pro Tools 10 1 08-02-2012 12:16 AM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
Issue When running Midi and more than one Midi Track amayhem MIDI 11 11-05-2009 06:52 PM
