Old 04-18-2016, 07:07 PM
Boult Boult is offline
Default External preamp & Monitoring thru digital in and out
First of, thanx ahead fo your help !
I want to add an "SSL Alpha Channel" and a "Dangerous Music SOURCE" to my rig. I want to connect them digitally to my 11R. The SSL to the SPDIF Input and the Dangerous Music to the AES (or SPDIF) Output.
The goal is to completely bypass the 11R D/A - A/D converters...
Can the 11R do that ? Would it work ?
Would the 11R Record from the digital in AT THE SAME TIME (with no added latency) as it would monitor thru the digital out ?
Mix through external preamp, natelikesoreos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-23-2009 04:55 PM
Digital Mic Preamp? Composer83 Pro Tools TDM Systems (Mac) 11 02-11-2009 03:59 PM
Using an External Preamp ubrnostrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-18-2008 03:37 PM
Focusrite preamp- digital??? svennib Tips & Tricks 5 06-26-2007 12:42 PM
Using a External preamp E-Buzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-07-2006 05:12 AM
