Old 08-31-2012, 10:00 AM
cablet cablet is offline
Default Omni vs. 8x8x8
Hello,
I know very little about Pro Tools but need to purchase a system right away for a project we are working on. We don't have our sound designer yet so I can't get his/her opinion on that matter.
The purpose of the system is to record scratch dialog and create temp mixes. Our final record sessions and mixes are done in other facilities where they know what they are doing.
We will use two mics when recording and will mix 5.1 mixes.
Our previous sound designer highly recommended the OMNI HD. I've had other people recommend the 8x8x8 with a decent dual channel mic pre amp. For gain control in our mixing room I'm using a Datasat AP20 with JBL cinema speakers via Crown DSi amps.
Can anyone tell me if one way is much better than the other in regards to the OMNI vs. 8x8x8? How are the mic pre amps in the OMNI?
Thanks for any feedback regarding this.
-cablet
Old 09-02-2012, 10:09 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Omni vs. 8x8x8
Omni as an I/O is 4 in 8 out.
Vs. 8 in 8 out for the 8-8-8.
From there on they're different.
Already having a monitor setup lends itself to using the onmi as an Interface / non-monitor device. This does affect the Monitor capabilities such as no headphones when it's an interface.
This does not affect the the 2 switchable Mic/Line inputs.
I personally would have liked the "Alt" for switching between a monitor device or an interface device for they both present different paths/control levels to my monitor-controller.
(As a monitor controller you can't record or externally meter your outputs without volume knob influence)
The preamps are fine and you can still add inserts for hardware compression. or just add a mic pre of choice to the front end.
It saves you a grand and can be flexible as well as limited.
Also consider if you have existing wiring, changes may have to be made.
Old 09-02-2012, 03:17 PM
nst7 nst7 is offline
Can you clarify what you mean by "no headphones" when used as an interface? Because that sounds incorrect, but I may have misunderstood you. And I don't know what you mean by "used as an interface".
Old 09-02-2012, 05:00 PM
Actually, OMNI is an 8x8 interface(total of IO, combining analog and digital paths) that also includes 2 preamps, monitor controls and headphone feeds, which makes it handy for a user that needs all that, and not much more(Omni has 14 actual inputs, but can only route a total of 8 into a Pro Tools session). The HD IO's(8x8x8 and 16x16) all can handle 16 ins and outs. 8x8x8 has 8 analog IO and 8 digital IO on lightpipe. 16x16 has 16 analog IO. There's also the 16x16 digital which has no analog IO at all. Since the Omni is the only HD interface with mic preamps and headphone jacks, the other HD interfaces require some other gear to complete a working system. Usually, that would include mic preamps(could be external boxes, or analog direct outs from a console), and a headphone amp(lots of solutions there, starting at about $50) and some kind of monitor controller(D-Box, or Presonus Central Station are 2 options). Hope that helps
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 09-03-2012, 04:49 AM
DetroitT's Avatar
No headphones for analog 1-8 out.(Hardware monitor to None and assign analog out;s 1-2,-3-4,5-6,7-8)
Cue via 9-10 and input feeds pass to headphone but not 1-8 analog (Unless record input is used)
I've now got the monitor as hardware and I/O with sub-bus's working for my flow. (My previous I/O was the 192 8-8-8)
(one-Hardware and I/O setup, 7.1 wide with many sub-bus variations)
PS
Omni is so flexible that it's taken me a bit to get use to. My setup uses the monitor section and I trim the Vol. to +4 via RMS volt meter, Keep the CC4 and meter-bridge and use a MOT 896 as core feeding the AES ins to the Omni 5-6
Old 09-03-2012, 07:18 AM
So it sounds like you must be using an outboard monitor controller and have your Omni outs as just straight line outs, correct?
For the headphones, would it work to use Cue 9-10, and then add an aux send on all channels (or on groups) and send that to 9-10? Either that or have each track's output going to both 1-8 and 9-10 (by shift clicking, or however it's done).
But if you're on HDX it might use up too many voices, so maybe that wouldn't be ideal.
Old 09-03-2012, 03:10 PM
DetroitT's Avatar
Yes the Shift Control to add outputs does work and aux send as you've indicated.
I finally have my head-arround and use the monitor assignments and so far so good.
My Controller (THX-CC4) (4x 5.1 in's by 1 gained 5.1 out and 1 pass through out for meters.
The surround/height/rears time share with cue during tracking (7-8) (Switched mirrored 7-8 TRS out)
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 01:00 AM
Pro Tools not seeing all i/o from Omni & HD 8x8x8 Steve1 Pro Tools HDX & HD Native Systems (Mac) 6 03-12-2013 05:59 PM
OMNI or 8x8x8 for 5.1 FX editing? sound01 Post - Surround - Video 19 11-29-2011 04:19 PM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
