Old 06-11-2008, 06:23 AM
TJS TJS is offline
Default Plug-In Settings root folder problem
hi
we have several HD2 systems here running 7.4cs4. i want to point all the systems to a common folder to store our plug-in presets.
so i go to a plug-in 'settings preferences' and change the 'root settings' folder to my new location. i've set up a 'plug-in settings' folder as described in the manual and i've made sure that settings are being saved to the root settings folder.
but it seems that only some plugins (such as altiverb, d verb, pitch) are happy with the new folder. other plug-ins (such as focusrite d2, d3, digi compressor/limiter) throw up the error;
'settings can only be saved to the "xxxxpluginxxx" folder inside the "Root Settings" folder or inside the working sessions plug-in settings folder, or sub folders of these folders'
i've tried trashing preferences, but that hasn't helped...
can anyone help?
thanks
Old 06-12-2008, 04:03 AM
TJS TJS is offline
Default Re: Plug-In Settings root folder problem
hmmmm.. is it just me then that has a problem changing the root folder for plug-in settings????
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Unable to save session copies w/ Root Settings Folder nuancerec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-03-2011 02:05 PM
Plugin "Set Root Settings Folder" PROBLEM dee dee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-09-2008 09:46 PM
Cannot save plug-in settings to Root Settings folder SimonORorke Pro Tools M-Powered (Win) 1 01-18-2008 08:38 PM
Plug-in Root folder problem michael c Pro Tools TDM Systems (Mac) 0 12-17-2007 10:59 AM
