Old 04-27-2004, 07:06 PM
lowaters lowaters is offline
Default How To Rename Session file to work on PC?
I am trying to open a pro tools session created on a mac on my PC. I already renamed all the audio files to aif, which works but what do I rename the fade files and the actual session file? Or can I?
Thanks
Old 04-27-2004, 07:53 PM
Paul14 Paul14 is offline
Default Re: How To Rename Session file to work on PC?
This has been covered a million times, but....
When you save the session on the Mac, there's a check box to enable PC compatability. Check it, and then you should be able to open it no problem on your pc.
Paul
Dell Pentium 4 3.0GHz, 800MHz FSB
1GB pc3200 DDR
60 GB Glyph FireWire
Digi 001, PT LE 6.1.1 - Screw 6.4!
Old 04-27-2004, 09:08 PM
seromaz seromaz is offline
.pts is the extension. but if they didn't check the mac/pc compatible box it's useless. Also in PT 6.X you create a session on your pc than import session data unde the file menu.
file rename after the fact? GloryIsSilent Tips & Tricks 5 06-09-2010 03:00 AM
6.7 MAC/PC Session File Conversion DOES NOT WORK! a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-17-2005 11:15 AM
rename file ZEUSS Pro Tools TDM Systems (Mac) 9 11-12-2003 01:40 PM
double click on session file doesn't work Brave Noise Pro Tools TDM Systems (Mac) 3 10-15-2002 04:43 AM
can't duplicate/rename file bluemt Pro Tools TDM Systems (Mac) 3 03-13-2001 01:30 PM
