Old 12-26-2020, 06:10 PM
atticmike atticmike is offline
Default Tools to test overclock with PT stability?
What tools and settings do you use to test Pro Tools' stability?
I've so far used Aida 64 with my 9900k but that doesn't really prove to be stable.
Pro Tools does tend to trash a lot even though Aida 64's only FPU Test was stable and I know it is based on voltage.
Do you think I should try small like prime 95 small FFT avx and go down from 5.1 to 5 GHz?
Gesendet von meinem SM-G965F mit Tapatalk
Old 12-26-2020, 06:31 PM
Default Re: Tools to test overclock with PT stability?
Why not underclock if stabilitynis what you need?
Old 12-27-2020, 11:54 AM
The Weed's Avatar
The Weed The Weed is offline
Personally I would try using the stock clock and use Processor Affinity, one core off with Hyperthreading off and two cores off with Hyperthreading on.
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 12-27-2020, 12:14 PM
What are you trying to achieve with overclocking? Usually overclocking is associated with gaming to squeeze a few more frames per second or for video rendering to reduce the time for rendering by a few percentage points. I'm not aware of any benefit for overclocking with Protools. I don't think you will get more tracks of recording or playback. Plugin performance is usually sample based so will see minimal improvement. About the only thing that I can imagine that can improve is bouncing to disk, and that will only be saving a few seconds per bounce. Maybe someone with experience with this can enlighten me.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 11.2.3 running Protools 2021.3.1
Old 12-27-2020, 04:59 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by atticmike View Post
... Pro Tools does tend to trash a lot...
You need to troubleshoot why PT is crashing. OC is not the solution.
Desktop: PT 2020.5 / Win 10 / GIGABYTE GA-X58A-UD3R / i7 hex 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.5 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 12-29-2020, 10:09 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
I have fifteen years experience with overclocking CPU's, and you can definitely get much more from PT with a stable overclock. More tracks and plugins, snappier. It's like having a faster and more powerful CPU... PT will always love that. Careful though, overclocking can be dangerous if you don't know what you are doing!
X99 | i7 5960x @4.6GHz | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro NVMe 256GB | Samsung SM961 NVMe 1TB | Samsung 850 EVO 1TB | Samsung MZ7PD256 SSD 256GB | Kingston 120GB SSD | WD Black 1TB x2 | G-Drive 4TB x2 | WD Elements 4TB | Audient ID14 | PT2020.12 | Windows 10 Pro
Old 12-29-2020, 10:20 AM
lesbrunn's Avatar
The difference between 5.1 and 5GHz would hardly be noticeable, and if 5GHz would make your system stable, by all means go for it. Tweaking your voltage can help with stability, but you should know what are safe voltages for your CPU, and good cooling is very important for a successful overclock. Some of these tools will overstress the processor and affect its lifespan. Asus has a utility that's efficient without killing your CPU.
Old 12-29-2020, 10:25 AM
lesbrunn's Avatar
+1. First make sure PT is stable at the standard clock rate, before you even think of overclocking.
Old 12-29-2020, 11:15 AM
I have also +40 years of experience hurting my knees and elbows when running too fast. So what was the point of overclocking again..?
ejinbc ejinbc is offline
OP
Overclocking the latest Intel processors is pretty easy - lots of great YouTube tutorials. You should be able to get ~4.9 GHz with almost any processor (higher OC usually means you were lucky with that chip). The trick is to find the lowest voltages (i.e. temperatures) at which any given OC is stable - so cooling is typically key.
For Protools OC, I have an 8700K OC to 4.9 GHz with a -2 AVX Offset. The AVX offset is critical. Protools uses AVX and that code can really heat up a CPU. So, when Protools is running this is equivalent to 4.7 GHz overclock - which is OK for me given Air Cooling and preference for quieter fans. My current system is 24/7 stable and quiet.
I don' think stress testing using synthetic benchmarks is a good way to optimize Protools overclocking. These tests push the CPU far harder than ProTools will, so I just use a BIG Protools session with lots of VIs and Plugins and let it go for 3 hours watching temperatures.
IMHO overclocking is perfect for DAWs because it lets you turn Turbo Mode off and all the C-state switching. This, for me, is the big reason to OC - and the ~10% performance increase is good too. As Les pointed out above, for low latency work with Buffers at 64 for 24/96 operation, an Affinity switch is required to free up one virtual core for the operating system - the best core to release MIGHT depend on the interface driver software.
Hope that helps. Best of the season.
ejinbc
Pro Tools 12.5 Stability Becharax Pro Tools 12 6 04-02-2016 10:50 AM
Pro Tools 12.4 and stability [Mac] dbdmusicproductions Pro Tools 12 7 12-28-2015 07:28 AM
[VIDEO] Eucon vs Command8 fader stability test jacko Avid Pro Mixing General Discussion 13 09-29-2015 11:41 PM
Is there an objective recording stability test? bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-01-2008 01:44 PM
Protools 6 stability test Chris Lambrechts Pro Tools TDM Systems (Mac) 0 04-24-2003 05:25 PM
