Old 11-08-2012, 02:38 AM
majikdragon majikdragon is offline
Default PT10 HD Native and UAD Apollo
Hello all,
I hope you can help as I'm at my wit's end.
I've just installed PT10 HD Native (10.3.2) and and a UAD Apollo Quad. These should work like a dream but they don't. They're running on a Mac Pro (early 2008 - 2 x 3 Ghz Quad Core) running 10.6.8 with 12GB of memory.
On startup PT gets as far as creating the DAE info and either crashes or says: "Pro Tools could not initialize the current playback device. Please make sure that the device has been configured correctly."
I have no idea how to do this. PT won't open so I can't tell it to use the Apollo. My Mac and Logic are both using the Apollo without any issues.
I've tried deleting the PT preferences, the DAE files, the IO settings.
Sometimes PT is automatically setting the mac to try and use "Pro Tools Aggregate I/O" - WHAT?
If anyone has any ideas as to how to get it working I'd appreciate it. I've seen PT9 HD Native working with an Apollo so it must be possible.
Cheers,
Sam Watts
Composer
Old 11-08-2012, 05:59 AM
simontheoracle simontheoracle is offline
Default Re: PT10 HD Native and UAD Apollo
I believe that you can only use your PT HD Native PCIE card with a qualified Avid interface like the Omni or one of the older Avid interfaces.
If you don't have the Native Card installed and have just installed the HD software, this should work with a 3rd party audio interface without any issue.
I have the HD software installed on my Macbook Pro and use an RME babyface as the audio interface.
Your best bet is to go into the Utilities folder under Applications on OSX where you'll see the Audio/Midi set up. Click on that and make sure your Audio is set to Pro Tools Aggregate for INS and OUTS. Set the clock to internal too.
If that still doesn't work then hold the N button whilst opening Pro Tools. A dialogue box should appear which allows you to select which type of audio interface you have.
I hope this works out for you.
Old 11-08-2012, 06:51 AM
Thanks for your reply.
I'm not great with technology. I'm clearly misunderstanding. I thought Native was what they were calling just having the software and using any audio interface. I'm clearly wrong.
I've got PT 10 HD software, no Avid hardware, and an Apollo. I don't understand why it's not working.
Old 11-08-2012, 07:51 AM
Did you go through the steps I gave you?
These links may also help you:
http://www.uaudio.com/blog/pro-tools-apollo-setup/
http://www.youtube.com/watch?v=zMEBBdweOwI
Good luck!
Old 11-08-2012, 07:53 AM
It sounds as though you're not using the HD Native card and just using the HD software which is fine.
You're better off putting your post on the Pro Tools 10 on OSX forum. You will will probably get more responses.
Old 11-08-2012, 10:44 AM
ianmiller ianmiller is offline
Your issue is that HD software either expects the HDX or HD Native PCI cards in your system in order to boot up correctly.
What you want is the standard PT 10 release. not the HD software. That will work with any audio interface.
Good luck.....
Old 11-08-2012, 11:00 AM
nst7 nst7 is offline
That's not correct. HD10 software works just fine without an HD card installed. It basically functions like regular PT and the Complete Toolkit.
So he should be able to use it with his Apollo.
Old 11-08-2012, 11:03 AM
Majikdragon, try holding down the "N" key when you launch Protools, and it may then give you the option. You should only have to do that once, and it should automatically give you the choice from then on.
Old 11-08-2012, 03:48 PM
Oops, you are right - I recall using mine without my HD stuff fine....sorry for the error....
Apollo 16 and HD Native EdFaris Pro Tools HDX & HD Native Systems (Mac) 25 04-29-2015 04:13 PM
PT10/11 and Apollo 16 Latency Issues Barry Johns Pro Tools 10 13 02-17-2014 07:24 PM
HD native and Apollo questions ianmiller Pro Tools HDX & HD Native Systems (Mac) 1 01-04-2014 11:50 AM
Apollo users on Windows w/PT10 JGlen Pro Tools 10 0 12-11-2013 09:53 PM
PT10 and UA Apollo setup indoe macOS 3 09-01-2012 12:50 PM
