AudioSuite does not work properly.
When I select a region to apply an AudioSuite effect (gain, pitch shift, etc.), the region remains unaffected. The processed file is created in my Region List pop-up, but the original highlighted region is the same. I can manually drag the file from my Region List to its intended place, but this is very time consuming. This problem occured mid-session for the first time ever in the 3 years I have had my current set-up. I have already tried to "trash PT preferences," but the problem persists. Any suggestions?
Re: AudioSuite does not work properly.
There's an option (I think in Preferences) that will place the processed region where it should be, instead of the Regions Menu. Just check it off.
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
In the AudioSuite window, highlight the box "Use In Playlist".
That'll do the trick |
I can't get my Mic to work properly | Djgman925 | macOS | 8 | 08-22-2013 01:53 PM |
882 will not work properly with 888 | dwall | Pro Tools TDM Systems (Win) | 0 | 08-30-2007 12:20 PM |
can't get plug ins to work properly | Chris Wate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-27-2006 04:12 PM |
Command 8 not work properly | webby | ProControl, Control|24, Command|8 | 3 | 07-21-2005 09:41 AM |
MDW installer ver 1.1 does not work properly | KK Proffitt | Pro Tools TDM Systems (Mac) | 2 | 03-07-2004 08:29 PM |
