Old 05-26-2020, 04:10 PM
jgiannis jgiannis is offline
Default Change Frame Rate mid-production
Hi.
I started building a large project on top of a 24fps video.
I'm in the middle of it, and Production is correcting future cuts of the video to 23.976fps.
Is there a simple method to force all of my clips to align to the new rate?
Old 08-20-2020, 04:50 AM
ViTheVault ViTheVault is offline
Default Re: Change Frame Rate mid-production
Hey, Did any one answer you ?
Did you find a way around.
I kind of have the same issue.
I received a Film in 23.976 worked on it. and now the grader discovered that few scenes are shot at 23.976, and the rest of the film is in 24.
So he's asking me if I have a way to correct that, if he sends me the whole film in 24. So they will convert the 23.976 to 24 ...
I had many desynced that I had to resync manually. So now that I understand why...
Is there an option in that manner, if he sends me the whole film in 24?
Should I pull up the whole export after mix is done and we're good?
Or should I receive the 24 and re-edit/sync and go to mix?
Any word of comfort or not, would be good...
Thank you
Frame rate change after finalising TrentWilliams Post - Surround - Video 2 05-16-2016 11:55 AM
How to change frame rate of AAF. Wawili_Sound Pro Tools 11 6 03-23-2015 07:12 AM
auto matching pull factors + frame rate + timecode rate Dingo90 Post - Surround - Video 1 10-17-2009 04:16 AM
Free Frame Rate and Frame Calc widgets dr sound Post - Surround - Video 1 08-21-2008 11:39 AM
QT 23.98 video frame rate... timecode rate? dopplah Post - Surround - Video 10 07-03-2007 05:28 PM
