Old 07-12-2018, 01:39 PM
s.d. finley s.d. finley is offline
Default C/24 metering with non HD version of Pro Tools
Hi all, we have 3 Pro Tools rigs at our studio here in humid Houston, TX. 2 rigs running 2018.3 HD software, HD Native card and one with 2 Apollo 16s and 1 regular PT ultimate with a C/24 and using a Mytek DSD DAC for monitoring. I admit I have never used the C/24 with a non HD PT system until now. Normally I have the main output metering appearing on the C/24 on the main metering to the right of the bridge. In the HD versions of the software I can enable and pick the pair out outputs I wish to meter. With the non HD version that option isn't available in the I/O selection so I cannot enable the main meter output. Is this an HD only feature?
sdf
www.sugarhillstudios713.com
Old 07-12-2018, 07:37 PM
Default Re: C/24 metering with non HD version of Pro Tools
figured it out, just had to default the I/O of the other sessions, which were recorded on HD systems and the main output metering reappeared on the C/24.
sdf
Old 07-12-2018, 08:48 PM
YYR123's Avatar
YYR123 YYR123 is offline
Ahhh cool cool - didn’t make sense that the features were only HD (or ultimate as they now call it) since the C24 can be used with native vanilla and HD alike
Daniel
LUFS Metering in Pro Tools conorkelly Post - Surround - Video 11 01-24-2018 09:00 AM
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but Patrick H macOS 3 11-20-2012 02:46 PM
Pro Tools Metering Accuracy Dot Pro Tools 9 25 03-02-2012 11:03 PM
Is Pro Tools metering questionable? Doctor Swing Pro Tools TDM Systems (Mac) 12 10-03-2005 04:49 PM
Metering in Pro Tools jimbob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-22-2004 06:39 AM
