Dead text window on D-Command
Hi all,
Anyone lost an upper text window on a blue D-Command? No top text window on channel 4. I've reset firmware, etc. It is blank when I run the internal diagnostics. I swapped it with the top panel from my Fader Pak and it worked so the connections and power must be good. Any suggestions other than running through the "new improved" Avid tech support?
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.3, PT2023.12.1, HDX, S1/Dock M1 PRO MacBook Pro OS 14.3, PT2033.12.1, BabyFacePro FS |
Re: Dead text window on D-Command
Hi Will,
Worth a try is to go to utility mode and crank brightness and contrast settings to low and high extremes. I've seen that bring the scribble back to life. Chris
Chris Lambrechts Applications Specialist- Live Sound |
Good idea, tried it, no love.
If I press lightly on the display it lights up but only a few pixels work. I'm tempted to just take the thing apart and see if a solder touch up is in order.
As it turns out the display modules are socket mounted. YAY!
Will, I was wondering how did you replaced it? Is it easy to DIY? Did you order the part from Avid? Thanks! Luc |
I ordered the part from Avid. If you have experience taking things
like this apart it's easy.
Is it Expensive? Cheers Luc |
nope.
After 8.0.3 install, no text in workspace or relink window | inasimplerhyme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 12-10-2014 12:53 PM |
Dead undo switch on D-command | Jambroch | ICON & C|24 | 3 | 04-28-2013 07:50 AM |
Dead D-command | mark linett | ICON & C|24 | 1 | 01-14-2011 08:02 PM |
Command 8 dead fader already?!! | mantaray | ProControl, Control|24, Command|8 | 4 | 08-24-2006 05:48 PM |
DEAD DSP in usage window? | brasssail | Pro Tools TDM Systems (Mac) | 2 | 05-18-2000 08:06 AM |
