Old 12-18-2009, 02:00 PM
mm4dman mm4dman is offline
Default Help: 002 mixer faders locked
When I pull up a session in pro tools, the faders snap to the corresponding faders in pro tools as they should. When I try and move the faders on the 002, they jump back up to their locked position like track automation is on, when it isnt......But, when I move a fader in pro tools the fader will move on the 002......I have run the 002 through fader caliberation and everything seems to be fine...I'm thinking its a setting in pro tools that might turn off the locking on the faders?
I just got this 002 yesterday and I really have no idea what to do i've been searching on the internet but cant seem to find anything.....
help please!!!!!!
Old 12-18-2009, 10:06 PM
Default Re: Help: 002 mixer faders locked
First, make sure the 002 is plugged into a grounded AC outlet. A solid ground is required as the fader caps are conductive and read the capacitance of your skin(I hope you did not replace these with plastic caps). Using plastic caps without the conductive silver paint would cause this. Sometimes when it gets extremely dry, you might get this too. A pain in the neck solution would be to use a wrist grounding strap. Also, since we are talking about a DIGI002, I suppose its possible that the power harness might be causing a poor connection to the PCB that feeds the faders, so you might consider re-seating the harness(several times on each of 4 connections).
PT6 to PT8 and 002 faders are locked JonM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 01-29-2013 03:34 AM
Why are faders locked on my 002? Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2006 03:03 AM
Faders Are Locked? thebends9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-26-2005 04:02 PM
Faders seem to be locked Please help. Shane Henry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-19-2005 12:25 PM
Locked Faders Jerry K. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-03-2004 10:37 AM
