Old 12-03-2009, 10:45 AM
blizzard's Avatar
blizzard blizzard is offline
Default Mbox 2 Mini - Laptop & Usb Hub?
Hey All,
I am trying to get a simple laptop editing and VSTi rig setup and have a question about the Mbox Mini. Are there any working setups out there that incorporate a USB hub? I have two USB ports on my Macbook and need my midi controller, iLok, and Mbox Mini all hooked up at once.
Cheers,
Andrew
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9
Old 12-03-2009, 10:52 AM
blizzard's Avatar
Default Re: Mbox 2 Mini - Laptop & Usb Hub?
I should mention that I do know that usb hubs are unsupported by Digi. But sometimes you savvy people have ways of making things work...just thought I'd check!
Old 12-03-2009, 11:01 AM
tho3hite tho3hite is offline
In their list of Do's and Don'ts Digi tells us not to use USB hubs (and not to do a lot of other stuff too). However in another thread on this forum a user representing DigiTech support suggested that he had fewer problems with his set up when he hooked his M-Box to a USB hub.
Old 12-03-2009, 01:09 PM
blizzard's Avatar
I have searched for the thread you mention but can't seem to find it...do you have a link?
I'm thinking that I will just get a powered usb hub and use that for my iLoks and Midi Keyboard, and then my Mbox will have a dedicated usb port.
Anyone using both an iLok (or multiple iLoks) and a Midi Keyboard on a usb hub?
Does anyone foresee any problems with running this many usb devices alongside the Mbox Mini?
Andrew
Old 12-03-2009, 01:19 PM
http://duc.digidesign.com/showthread.php?t=194592
Old 12-03-2009, 01:58 PM
Dism Dism is offline
Andrew
Always always always plug the MBox directly to a USB port. No hub, no anything in between. Everything else is fine. I run my MIDI devices, iLok, iPod, etc etc through a hub in the other port, just NOT the MBox. As long as you keep it on it's own port, you should be fine.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-03-2009, 07:21 PM
getz76 getz76 is offline
The iLok is fine on a powered hub. I would guess most MIDI devices will also be fine on a powered hub, but it really would depend on the device.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 12-03-2009, 07:40 PM
Generally, my rule for USB hubs is don't use them for system critical devices. I never use them for audio interfaces, and I tend to avoid using them with hard drives when possible, though most of mine are FW now. If you have USB video interfaces, and other similar devices, it is typically recommended that you don't use a hub. However, hubs are very useful for powered, low-data devices, i.e. MIDI devices.
I've used several different MIDI interfaces, be it control surface or input device, and they all seem to benefit from a powered hub, since most of them are powered via USB alone. MIDI is also a comparatively small amount of data to send/receive, so it is unlikely that a hub will mess with it. Typically, my hub will have my laptop cooler, ipod/cell phone, ilok and my AlphaTrack (HUI control surface) all plugged in. The MBox stays in it's respective USB port by itself. I've never had any related issues with this setup.
D
Old 12-04-2009, 10:17 AM
blizzard's Avatar
Great!
I'm going to pick up a powered USB hub and plug my 2 iLoks, midi controller, flash drive, and usb mouse into the hub and my Mbox Mini into the other. This way I can also experiment with using the powered hub with the Mini and see what happens.
But first, I shall upgrade from 7.3.1 to 8!!! Been waiting for this one!
Cheers,
Andrew
pro tool le 8 with mbox 2 mini which laptop will work best jakekeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-29-2012 07:18 PM
Mbox 2 Mini - Laptop & Usb Hub? blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-04-2009 10:14 AM
Best Laptop for Mbox Mini fizak General Discussion 2 06-25-2009 01:15 PM
Laptop recommendation for MBox 2 Mini???? JJshred 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-20-2008 12:58 PM
Asus laptop and mbox 2 mini pekaboo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-16-2007 05:52 AM
