Old 04-10-2009, 03:40 PM
Herkimer Herkimer is offline
Default Anyone tried PT8 on a new mini-laptop with Atom processor?
ok... ok... I know someone is immediately going to pipe in that it's "not supported." Great. Whatever. I accept that. I just want to know if it works.
So has anyone tried PT on one of those new mini-laptops? They come with an Intel Atom processor and 512Mb Ram. They run XP and have flash memory drives (two separate drives).
I spend two hours a day on a train and would love a mini-setup (smaller than my current full-size laptop) to tinker with drum programming and midi programming.
And they're so darn CUTE!!!
Old 04-10-2009, 03:44 PM
Default Re: Anyone tried PT8 on a new mini-laptop with Atom processor?
Check here if you haven't seen these things yet:
http://www.dell.com/home/laptops?~ck...-mini&navla=&a=
Old 04-10-2009, 04:13 PM
sonicapg sonicapg is offline
I dont know the reply on this ,but PT needs a QUALIFIED cpu to run.
I believe that Atom isnt qualified.
I also have serious doubts about the hard disk controller in these devices of any brand, for use with PT8
Old 04-10-2009, 04:47 PM
paulrgmusic paulrgmusic is offline
I don't know about the processors but I'm pretty sure that PT LE8 requires at least 1GB of RAM and will not install if the system does not meet this requirement. I don't know if you can easily upgrade the RAM in these netbooks.
Paul
Old 04-10-2009, 07:52 PM
msg6794 msg6794 is offline
from what i've read, an atom is considerably slower than a celeron running at nearly half the speed! i don't have high hopes for pt running at any useful level on one, which is a shame since the size and battery life of those things is otherwise nice!
http://laptoping.com/intel-atom-benchmark.html
003 Rack | Dell Studio XPS 8700 (Core i7 4790, 16GB RAM) | Windows 10 64-bit / PT 12.6
Old 04-11-2009, 08:14 PM
epu epu is offline
The Cpu power will most likely be a serious issue, but that said, when I asked around whether or not the 12" Ultraportable IBM X31 would run, I was fed the same scoffs about the processor being inferior and lack of this and that making it not run.
You know what? I've been running them on the ultraportable line ever since. Without a hitch, BETTER than most laptops and OFF the system drive to boot. That said again, there's a HUGE difference between an Ultraportable Thinkpad and an Atom Processor Netbook.
At $299 though +/-, its worth a try . . .
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 04-12-2009, 06:24 AM
I found a site where someone claims to have PT 7.4 working on an Atom processor Asus Eee.
Look in the comments posted to the following article:
http://createdigitalmusic.com/2008/0...-3-linux-tips/
Think it's for real?
Old 04-12-2009, 11:29 AM
rqstudio rqstudio is offline
I believe this statement is not true but purely the stock answer you get from Digi. Maybe they should change their replies to "Qualified" or "Not Tested." In fact, I'll bet they are at least a year behind testing laptops. I'm running 7.4 on a AMD Turion laptop, and ver 8 on an AMD 4,000 + PC, neither have been tested theirfor not qualified, however both are running excellent! If you want to save yourself some greef follow Digi's gidelines, if you feel like living on the edge, experiment!
Old 04-12-2009, 09:22 PM
Shan's Avatar
Shan Shan is offline
I believe local DUCer MattP has done so successfully. He might chime in with an update.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 04-13-2009, 03:20 PM
Tom Case Tom Case is offline
Hello,
I have PT 8 loaded onto an Asus n10. 1.6 atom, 2 gigs of ram, vista. It installed no problem, and starts no problem. I loaded band practice into it, 1 hour stereo wav. , to edit. Many, many errors. Never crashed, but I wouldn't call it "working". I did finish editing the session and bouncing out 5 minutes of stuff we might use, but I was determined. One thing I couldn't figure out was "1 processor" was greyed out forcing me to use "2 processors". XP or 7 might get you further, but since I never intended this to be a DAW I haven't tried. Hope that helps.
Tom
Soundmaster ION ATOM japple Buy & Sell 0 04-30-2013 07:46 AM
Serious MIDI problems on Mac Laptop (i7 processor) Groovacious macOS 0 07-23-2011 12:32 AM
New Dual core atom Hotcrazyfruit General Discussion 0 10-24-2010 06:32 PM
Laptop issues with Dual Core Processor, please help!!! andyaynow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 07-26-2007 05:02 PM
Windows Laptop Compatibility - duo core processor smackeroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-07-2007 06:03 AM
