loop sync problem
My setup is:
HD system with two 192's, Accel card, 2.0 Ghz G5 Mac with 4 GB RAM, Mac OS X 10.3.3, Logic Audio 6 Pro 6.4.2, Digi Coreaudio 6.4. One 192 (the primary one) is synced from an Aardsync wordclock (44.1) to it's loops sync in, it's loop sync out goes to the loop sync in of the other 192. This was working before, but I recently moved this studio and rewired everything. I must have switched the primary and secondary boxes around, and now they won't sync to the Aardsync. I've tried three different BNC cables and outputs from the Aardsync for word clock. I know the Aardsync works because other boxes are synced to it, and, in order to get around this problem, I'm syncing an Eventide box to the word clock on the Aardsysnc, and then syncing the 192's via AES/EBU to that (so they ARE getting sync from the Aardsync, but indirectly). I've tried switching the WC to the secondary 192 instead, makes no difference - every time I try to set up the sync to external word clock, I get the message "your hardware has no sync". What could I be doing wrong? |
Re: loop sync problem
I hope this helps.
Bryan Jackson Independent Audio Systems Engineer Burbank,CA / Las Vegas, NV |
Sync I/O and a single 192 I/O Loop Sync or not? | Zapakos | Pro Tools TDM Systems (Win) | 8 | 06-12-2016 08:41 PM |
Midi Clock Loop Sync problem | tilman | MIDI | 10 | 03-09-2012 11:37 AM |
Sync HD, Loop Sync, Max BNC Length? | matchoo0 | Pro Tools TDM Systems (Mac) | 2 | 08-07-2010 01:31 AM |
Problem with Hardware on Midi sync on Loop mode | Alexia | MIDI | 1 | 01-16-2010 06:40 AM |
loop sync cable problem | jre3132 | Tips & Tricks | 1 | 03-23-2007 09:10 PM |
