Pro tools sound output no working after click sound
Hello,
I am having a recurring issue while working on a specific session. I can work on it for 5mn and at some point I hear a click/pop sound and then I have no sound. The master level are all saturating and stay like that with no sound ( see screen cap ) I never encounter that problem on other sessions. That session is heavy, I have a bunch of plugins (synths, mixing tools..) running but I often work with that many tools and I am wondering why on that one it creates a problem. I have to restart pro tools or even reboot my mac to undo that error. Please let me know what parameter I could change to fix it. I am working with Pro tools 12, Eleven rack. H/W Buffer size: 1024 Cache Size: Normal I also run a few samples. A pad sample that is located on an external HD played via the plunging MOTU Mach5 sampler and a little drum kit also located on that HD and played via the Motu BPM drum machine plugin. Could that affect drasticaly the system usage? I get the messages/alerts saying: "Solo mode has been changed to SIP-only, as DSP resources are insufficient to use AFL/PFL. Try Freeing up DSP by making some tracks or plug-ins inactive." or "Pro Tools ran out of CPU power. Try de-activating or removing Native Plug-ins. (AAE-9173)" It might be that I am using too many plugins... I understand that I need to remove some of them but my question here is why do I have to completely restart my sessions each time the sound/output is not working any longer. I used to have crashes on pro tools 7/with Mbox - I would just change the Buffer size to another setting and then I would just change it again to my working Buffer size setting and the sound would come back easily. Today I tried that, I am trying to fix that issue without having to close pro tools or even to reboot my mac. Do I have to change something in the "disk playback"? I hope my explanations are precise enough to give you a hint on what's going on with that session. Thank you for your advices |
Re: Pro tools sound output no working after click sound
Isn't there a bug with the Click plugin?
Either way, try deactivating/reactivating the plugins or track(s). Otherwise, switch the buffer size to something else (and back) and see if that cures it. Lastly, a restart of Pro Tools and maybe the Mac/PC too. If all that fails then trash prefs! Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
I don't use the Click Plug In on that session. I tried deactivating the plugs already but still no sound. Its like something breaks in the session and i can't fix it unless I close it and re-open the session completely or reboot pro tools.
I did try the Buffer size switches.. What prefs should I erase? Where are they located? Could that affect other parameters of my setup? Thank you Stephen. |
Start here http://www.petegates.com/pg-pt-prefs.html
Also here... http://duc.avid.com/showthread.php?t=54888 Stephen
I had this crop up for the first time after 20+ years of PT use. I am certain it's a 3rd party plugin or a combination that doesn't play well together.
The sessions loses clock (hence the click), and some of the PT meters stream to peak in a cycle from the upper area of the meter scale. I would NOT get an error message though. The session(s) would get completely hung up clocked internal or s/pif I narrowed it down to either Slate or Sound Radix Surfer EQ. Haven't had time to narrow further.
Ron Allaire 3ID NYC Reservoir Studios NYC Home rigs: Mac pro 5,1 2.66 nehalem quadcore (10.12.2 &10.13.1),24g ram,sonnet firewire 400 card, Samsung ssd 3-1T WD Caviar black (internals), 002r, PT 12.6.1 HD & 12.8.2.106). Macbook Pro 2.5ghz quad (10.12.2),16g ram, 2 X SSD (internal),PT 12.4 HD |
Thank you for all your advices I am going to try removing the plugins one by one to see where it interferes. I will let you know how it goes and if I don't find the issue, I will trash some prefs.
I fixed the problem removing some plugins. I think the MOTU ones were not behaving correctly in that particular session.. still a mystery but that happens. Now everything works perfectly. Thank you again for your advices.
Pro Tools HD 10 Not Recording To Track - And No Sound output | mw32768 | macOS | 8 | 12-30-2018 07:10 PM |
Sound and video randomly stops working when HD Native is selected as output. | Focuret | Pro Tools HDX & HD Native Systems (Mac) | 3 | 01-24-2017 12:15 PM |
Possible to have system sound output set to HD Native while Pro Tools is running? | Focuret | Pro Tools HDX & HD Native Systems (Mac) | 10 | 12-08-2016 08:20 PM |
Pro Tools 10 Bad Sound Quality on Click Tracks? | matze233 | Pro Tools 10 | 0 | 06-10-2012 06:41 AM |
Audacity Sound, Reaper Sound, Pro Tools NO SOUND | RoganX | Pro Tools 10 | 3 | 03-18-2012 09:06 PM |
