Help! PT11 - Instrument-track PB/REC issues & DPC latency?
New member here, and hoping for some help on these 2 issues - which I'm suspecting might be kind of related. Though I'm no expert on this hardware/tweaking stuff myself. When playing a instrument track (only) session, with as less as 4 tracks, I'm experiencing weird note-cut-off's. Sometimes whole session will stop playing, except from random notes being monitored through speakers. I can save my session I've done a DPC Latency-test, and the "USB-3 intel host controller" driver seems to go through the roof on my system. And longer the test - higher the digits on the "driver-tab" in "latencyMon" software. Has anyone experienced this? (The mainpage says my system is having difficulties with running realtime playback) How can I resolve this? I already disabled CPU throttling in the BIOS, I've turned off all power-management to turbo CPU in BIOS. I did the power-management settings in WIN7, and running PT as admin. But I just can't seem to figure this out. Does anyone have experience with this? Perhaps someone with similair system-specs?? FWIW... Here's my Sandra Report; SiSoftware Sandra ID Host Name : WolfPack-Recs Workgroup : WORKGROUP Computer Model : ASUS All Series ASUS MB Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS X99-DELUXE Serial Number : 1411353******** BIOS : AMI (OEM) 1702 04/10/2015 Intel vPro : 9.01.10.1005 Total Memory : 15.9GB DIMM DDR4 Processors Processor : Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz (6C 12T 3.6GHz, 3.6GHz IMC, 6x 256kB L2, 15MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : Intel Xeon (Haswell-E) DMI2 100MHz Memory Controller : Intel Xeon (Haswell-E) Integrated Memory Controller 0 Target Address, Thermal & RAS Registers 100MHz, 4x 4GB DIMM DDR4 2.13GHz 256-bit Memory Controller : Intel Xeon (Haswell-E) Integrated Memory Controller 1 Target Address, Thermal & RAS Registers 100MHz Memory Module(s) Memory Module : Kingston KHX3000C15D44GX 4GB DDR4 PC4-17100U DDR4-2134 (15-15-15-37 4-52-17-6) Memory Module : Kingston KHX3000C15D44GX 4GB DDR4 PC4-17100U DDR4-2134 (15-15-15-37 4-52-17-6) Memory Module : Kingston KHX3000C15D44GX 4GB DDR4 PC4-17100U DDR4-2134 (15-15-15-37 4-52-17-6) Memory Module : Kingston KHX3000C15D44GX 4GB DDR4 PC4-17100U DDR4-2134 (15-15-15-37 4-52-17-6) Video System Monitor/Panel : SAMSUNG (1600x1200, 7.2") Video Adapter : AMD Radeon R9 200 Series (44CU 2816SP SM5.0 1GHz/1GHz 5% OC, 16kB L2, 4GB DDR5 5.4GHz 512-bit, PCIe 3.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon R9 200 Series (2816SP 44C 1GHz/1GHz 5% OC, 16kB L2, 4GB DDR5 5.4GHz 512-bit) Compute Shader Processor : AMD Radeon R9 200 Series (2816SP 44C 1GHz/1GHz 5% OC, 16kB L2, 4GB DDR5 5.4GHz 512-bit) OpenGL Processor : AMD Radeon R9 200 Series (2816SP 44C 1GHz/1GHz 5% OC, 16kB L2, 4GB DDR5 5.4GHz 512-bit) Storage Devices Samsung SSD 850 EVO 120GB (120GB, SATA600, SSD, SED) : 112GB (C:) KINGSTON SV300S37A120G (120GB, SATA600, SSD) : 112GB (H:) Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (G:) TOSHIBA DT01ACA200 (2TB, SATA600, 3.5", 7200rpm) : 2TB (F:) ASUS DRW-24F1ST a (SATA, DVD+-RW, CD-RW) : N/A (D:) Logical Storage Devices Reserveret til systemet : 100MB (NTFS, 4kB) @ Samsung SSD 850 EVO 120GB (120GB, SATA600, SSD, SED) SSD2 (H:) : 112GB (NTFS, 4kB) @ KINGSTON SV300S37A120G (120GB, SATA600, SSD) Reserveret til systemet : 100MB (NTFS, 4kB) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Games (F:) : 2TB (NTFS, 4kB) @ TOSHIBA DT01ACA200 (2TB, SATA600, 3.5", 7200rpm) Hard Disk (C:) : 112GB (NTFS, 4kB) @ Samsung SSD 850 EVO 120GB (120GB, SATA600, SSD, SED) Hard Disk (G:) : 466GB (NTFS, 4kB) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Optical Drive (D:) : N/A @ ASUS DRW-24F1ST a (SATA, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : ASUS Wellsburg LPC Controller Audio Device : ASUS Wellsburg HD Audio Controller Audio Codec : Realtek Semi 0900 Audio Device : ASUS High Definition Audio-controller Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS Wellsburg sSATA Controller [AHCI mode] Disk Controller : ASUS Wellsburg 6-Port SATA Controller [AHCI mode] Disk Controller : ASUS Asmedia 106x SATA Controller USB Controller 1 : ASUS Wellsburg USB xHCI Host Controller USB Controller 2 : ASUS Wellsburg USB Enhanced Host Controller #2 USB Controller 3 : ASUS Wellsburg USB Enhanced Host Controller #1 USB Controller 4 : ASUS ASM1042A USB 3.0 Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB/IVB/HSW-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB/IVB/HSW-E XMB Ch 1 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) I211 Gigabit Network Connection (Ethernet) Network Adapter : Intel(R) Ethernet Connection (2) I218-V (Ethernet) Wireless Adapter : Broadcom 802.11ac Network Adapter (802.11n (HT), AES-CCMP, 144Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate Media Center 6.01.7601 Service Pack 1 Platform Compliance : x64 |
Re: Help! PT11 - Instrument-track PB/REC issues & DPC latency?
Bump, anyone?
Only me experiencing Haswell-E issues on PT11?? Seems, my intel USB-port driver creates intensive latency, makes my audio recordings cracking, popping and disturb. Anyone with similair system as mine solved this?
Win10 Pro x64 Asus x99 Deluxe Intel i7 5930k 3.5 GHz 16 Gb Kingston DDR4 Asus r9270 DC2 4Gb DDR5 Focusrite Scarlett 18i8 ProTools 12.5.1 Last edited by Hellan; 08-21-2015 at 07:23 PM. Reason: Forgot further details... |
Look into your sample rate/clock speed. If your sample rate is 512, try decreasing it to something under 300. This may or may not help. I also notice that anytime I run anything over 48khz clocking, I get distortion in the playback. I run an AMD system with Win 7 Home Premium and you running an Intel system may have totally different properties.
Recap: let us know what interface you have, and which plugin VI's are having the note issues(or is it all VI's)
It seems I'm missing something on the setup, I'm suspecting it's in the BIOS. Since, like you're saying, this system should be pretty descent at handling my needs. Most often like 10 tracks VI's, and a couple of audio as well. Also, I'm not really seeing it go bezerk in the system-usage window at any time. The 12 CPU threads are around max 20-40 percent, when I push it the most. 1. I'm on a Focusrite Scarlett 18i8, USB (plugged into USB 2.0 port for compatility issues sometimes on USB3.0 systems, so just to be sure I did it like this). 2. Haven't really checked for floppy on the BIOS, since there's no floppy device in my system. But will double check that - just to be 100% sure that's not causing the issue. Thanks for the tip. 3. I'm not entirely sure what you mean by odd amount of RAM. I have 4x4Gb Kingston HyperX, at base clock DDR4 inserted. There shouldn't be any onboard GPU, nor video output on the Motherboard. Also there's non on the 5930k Intel, as far as I'm aware. So no? But please elaborate? :) 4. I'm using Superior Drummer 2, Spectrasonics Trilian, and some tracks with Kontakt. Will try a reboot to check for floppy options in the BIOS and post further informations regarding this. If you can remember anything else, or other possible settings I might have forgotten. Please feel free to fire away!
Win10 Pro x64 Asus x99 Deluxe Intel i7 5930k 3.5 GHz 16 Gb Kingston DDR4 Asus r9270 DC2 4Gb DDR5 Focusrite Scarlett 18i8 ProTools 12.5.1 |
Yes, like I thought - was unable to locate ANY floppy settings. Only my HDD/SSD's and my DVD-RW in the BIOS. So that's not causing this issue.
I might have to locate/pay a person setting up this system for Audio Production, since I'm running out of ideas here.. - BTW, also disabled xHCI settings in the BIOS. Since I noticed alot of DPC latency from the intel USB 3.0 driver controller. So that should eliminate that potential issue aswell..
Win10 Pro x64 Asus x99 Deluxe Intel i7 5930k 3.5 GHz 16 Gb Kingston DDR4 Asus r9270 DC2 4Gb DDR5 Focusrite Scarlett 18i8 ProTools 12.5.1 Last edited by Hellan; 08-24-2015 at 02:28 AM. Reason: Missed USB explanation |
Re the RAM, I am confused on why its reporting 15.9GB out of the 16GB total. Is it possible that one stick of RAM is defective?
Re xHCI, I'm not sure what this is. If you meant AHCI, all your drives should be in AHCI mode and not in IDE mode(but I am on a slightly older rig here). Re the floppy drive question; I have read on several occasions that if BIOS "thinks" there is a floppy, it hurts performance(even if there is no floppy drive installed). It might(in BIOS) be referred to as Drive A: or B: as those letters are reserved for floppy drives only. I hope you can get it sorted out
Playback recording latency issues in PT11 | griploc | Pro Tools 11 | 12 | 01-24-2016 05:28 PM |
HELP with Low latency mode & instrument track | paul_g | macOS | 1 | 02-21-2015 11:44 AM |
ADC Audible Latency When ANY Instrument Track Is Record Enabled | Intransit | Pro Tools TDM Systems (Mac) | 13 | 09-15-2011 03:07 AM |
Strange Instrument Track Issues | RobtheRipper | Pro Tools TDM Systems (Mac) | 3 | 08-19-2008 04:00 PM |
Instrument Track phasing issues? | Jace Everett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-09-2007 03:58 PM |
