What kind of tracks are these?
I have tried to make a new track that is like these but every category I chose is not these. They have no fader knobs and only an input and rec switch. I want to use these in a new session but I can only duplicate them in this session and can't figure out what they are so I can make a new one in a new session from scratch. Do these look familiar? Thanks for any help. Picture is attached.
Re: What kinf of tracks are these?
They are stereo audio tracks, each of which has its output assigned to a mono bus. They have their "Input Monitor" button engaged, and a test signal (probably timecode, judging by the name) is being sent to their left input channel (ie input #3 of your audio interface)
Why . . . only you can explain ;-) |
(I'm assuming that is the issue here..?) T
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
Re: What kind of tracks are these?
I am a little bit confused , because they actually do have "Fader Knobs " they are the red rectangular buttons sitting at 0 db in the slider scale. I am guessing the problem you are having recreating them is PT is probably defaulting to the stereo main outs for any new stereo audio tracks, so you will have to create the tracks then select a mono bus from the dropdown when you click on the output selector button. Also note they are Input monitoring engaged and are record armed (thus the red faders )
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... |
I think he simply used the wrong terminology in his original post. I am guessing that he was actually referring to the missing "Pan Pots" (because of the direct mono assignment), and instead mistakenly called them "Fader Knobs".
Ah, yes the internets can be communication challenged
What kind of Mac is best?? Help! | galaxy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-06-2009 01:05 PM |
what kind of pc should i buy | thuglord | Pro Tools M-Powered (Win) | 2 | 08-06-2009 02:21 AM |
what kind of RAM? | arnobg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-28-2009 09:28 AM |
What kind of mic-pre is in a 002? | Soliton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-08-2005 03:27 PM |
This has nothing to do with PT...well kind of... | Nine Spine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 38 | 02-09-2002 12:17 AM |
