Focsurite Scarlett 18i20 not works
Hi all!
Firstly, sorry for my english, i don't use to use it. Well, my problem is that two weeks ago I bought a Focusrite Scarlett 18i20 since then i can not work with protools. First time I instaled drivers seemed that all works well... For now, Scarlett works well with Ableton Live but Protools doesn't recognize the interface.... I have tried everything.... Install current versions of Scarlett Mix Control and drivers, Install Beta versions of Mix Control and drivers, unable interface in my Windows client... Nothing have worked...... Some one can help me? Thank you! |
Re: Focsurite Scarlett 18i20 not works
Try pressing and holding N while starting Pro Tools and see you can select the 18i20 then. Can you post your full system specs?
I'm using an 18i20 here without issues. Although there are some setup oddities. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Hi Joel
I'm new to the forum hello : ) I've been having the same issue with my 18i20 I was using an MBox mini with no issues. I have installed the USB drivers version 2.5xxx this didn't work Uninstalled these drivers then tried the beta audio driver version 3.2b2 Holding N did nothing? Have you got any ideas? Thanks Chris |
By the way
I'm using a PC running windows 10 Pro 64bit Pro Tools 12 8.0 GB Ram Intel I7 2.7GHZ |
Some more info for you
Since installing the Beta drivers the Mix control doesn't work it says "no hardware connected" I can use the Scarlett to play music from my PC fine when I set it as the default audio device |
Ignore all my messages I think I've now done it! : )
In settings/manage audio devices - the recording tab was set to the scarlett I defaulted it back to the computer microphone then opened Pro Tools and it all seems to be working...for the moment : ) |
Ok, good to hear. If Mix Control is saying no hardware, then it is not a Pro Tools issue.
Generally, I disable my interface completely in Control Panel, Sounds and Audio Devices as I don't want Windows touching my interface. Joel
The Mix Control app and driver have to be made to work together. If the driver installs a firmware upgrade to the interface, the Mix Control app needs to be updated too. Download both the latest beta driver and Mix Control apps.
Pro Tools 11 with Focusrite Scarlett 18i20? | hermonmusic | Third Party Interfaces | 24 | 06-27-2015 08:53 AM |
Scarlett 18i20 and USB 3 on Mac | JCBigler | Third Party Interfaces | 1 | 11-09-2013 07:07 PM |
Focsurite 18i20 driver issue w/ PT11 | IsaacBrick | Windows | 1 | 10-02-2013 10:44 AM |
Focsurite 18i20 driver issue w/ PT11 | IsaacBrick | Pro Tools 11 | 0 | 10-02-2013 08:27 AM |
Could you help me with this, please? - Calibrating a Scarlett 18i20 | hermonmusic | Getting Started | 4 | 09-13-2013 08:33 PM |
