Old 06-10-2016, 05:36 PM
Barry Johns Barry Johns is offline
Default DB25 Male to DB25 Female Ext. Cable
I'm in the process of rewiring my studio. I've got one DB-25 cable going to my patchbay from my 192 I/O, but is about 18 inches short. I see on Amazon where you can get DB-25 extension cables for around 10 bucks, but I don't think they are shielded properly. Anybody out there got a recommendation for me, versus just buying a longer DB-25 cable?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 06-10-2016, 05:59 PM
Default Re: DB25 Male to DB25 Female Ext. Cable
Those cables are not designed for audio use, won't have differential pairs and grounds laid/twisted together, etc. And extra connections never help, so no forget it, just get a proper longer cable. Lots of good source for those.
Also not all "DB-25" cables actually connect all pins, the ones you are looking at are likely designed for RS-232/serial port/modem/printer connections and may or may not connect all pins, may cross over some pins or have extra "null modem" wiring between different pins.
Old 06-11-2016, 07:04 AM
I'll give another reason to replace with a longer cable; do you really want to add 16 more chances of a broken signal path? Let's face it, DB25 connectors are used to save space, but not because they are robust and solid While I don't usually recommend Hosa brand, I just installed several of their DB25 cables and(so far) they are all working dandy(and are not likely to ever move)
Old 06-11-2016, 07:51 AM
JFreak's Avatar
JFreak JFreak is online now
proaudiola.com sells great hand-soldered cables with your custom length
Janne
Old 06-11-2016, 08:59 AM
arche3's Avatar
arche3 arche3 is offline
Sweetwater sells different ended db25 audio extentions. I have a few.
Sent from my SM-N920V using Tapatalk
Old 06-11-2016, 09:45 AM
This one is designed to do exactly what i'm trying to do. Anybody have any experience with this?
https://www.amazon.com/Planet-Waves-...s=db25+coupler
Old 06-11-2016, 10:24 AM
arche3's Avatar
I have a couple of those. As well as the same brand cable extenders. They work fine. Good quality. I got them from Sweetwater.
Old 06-11-2016, 05:31 PM
Keith Robichaux's Avatar
Keith Robichaux Keith Robichaux is offline
One new cable from Chris at Redco. Sell the short one on Ebay. Chris did all my SSL dl's. He's great.
Mac 5.1,PT10HD, 192's, SSL 4040G+
keithrobichaux.com
@keith_robichaux -Twitter,Instagram
Old 06-11-2016, 06:58 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
+1 for Redco.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 06-11-2016, 07:26 PM
paulo m's Avatar
paulo m paulo m is offline
You said you´re 18 inches shorter, by the picture I don´t see this adapter having that size at all, unless you have another db25 to db25 to add.
Also, I wouldn´t advise you having this type of extenders, it´s just an extra and dubious contact connection on the audio path. You spent a lot on your converter and cables and now you want to insert a piece of plastic in between. Not the best option in my opinion.
I would buy a good quality extra long db25 to db25 cable with the same pinout to replace you´re existing one, going straight from the converter I/O to the patch. I´m assuming that you have a patch with a db25 connector on the back.
Alternatively, did you ever considered (if possible) exchanging the position of your 192 on the rack, closer to the patchbay?
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Re:female voice to male 2224 Tips & Tricks 10 01-09-2016 04:22 PM
Selling Dangerous D box & DB25/trs cable bonzerboy Buy & Sell 3 11-10-2014 04:27 AM
4ft DB25 Cable Heinz Kohlbauer Pro Tools TDM Systems (Mac) 0 02-19-2003 05:26 AM
Anyone know if a Tascam CU/SD105 db25 to db25 will do the job? juniperjuniper Pro Tools TDM Systems (Mac) 2 05-22-2002 12:30 AM
DB25 to DB25 snake Viditte ProControl, Control|24, Command|8 5 03-26-2002 03:03 PM
