stereo tracking and stereo sends
Hi all!
First it seems I can't Alt+Click+Drag a send from a track to another to copy it... how come? It also seems that even with a group toggled opening a send is not performed on each track of the group... How can I open the same send on many track at once? Second : I recorded some acoustic guitar with two mics. Say I pan one left and one right. What would you advice for the sends to RVerb then? I see mainly two options : Whether send each mono track to a mono aux with RVerb, or send each mono track as stereo (with lieft or right panning respectively) to a stereo Track with RVerb (st). Both don't give the same result. Sending mono results in more volume for the reverb while using the same settings with the stereo verb. What do you guys do? Any comment to this? Do you sometimes put different reverbs on each side? Also, what happens when you use a mono send on a stereo track? is it sending the sum L+R ? Thanks
TravelMate (2.5GHz, 1GB RAM)WinXP,PTLE 6.1.1, MBox, SP C1, Edirol PCR-30, Johnson J-Station DrumOnCans |
Re: stereo tracking and stereo sends
In the analog realm.. most of the time reverbs are sent from mono sends with stereo returns (unless you're doing a 5.1 mix) mainly because you have limited send pots or faders. The left and right is summed to the send.
Sends can't be dragged and copied -- I was promised this about 2 years ago.. but it hasn't materialized. Rail
Thanks Rail! Concise and clear! (much more than the question...)
It's a pity for the sends not to be able to be copied... Cheers.
Some Stereo Sends Read "NoSend" But Work Fine?!!?!? | David Pye | ProControl, Control|24, Command|8 | 1 | 10-31-2008 03:47 PM |
Reason 3 w/Protools - multiple stereo sends? | Joel Cage | Virtual Instruments | 3 | 03-05-2007 07:09 AM |
using a stereo aux with mono sends... | polf | Tips & Tricks | 2 | 07-28-2006 12:06 AM |
Tracking in Stereo | Musichead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-21-2002 07:56 AM |
mono vs stereo aux sends | Dead River Studio | General Discussion | 1 | 06-26-2001 07:22 AM |
