Old 05-29-2019, 08:22 AM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
Default Display & switch parameter automation in Edit window
In channel view, holding down Control and Command keys and tapping on the label of an insert parameter will display that parameter’s automation in the current track. Is this new to 2019.5?
If so how did I miss this!!
#timesaver
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch,
EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB
Old 05-29-2019, 09:14 AM
BScout BScout is offline
Default Re: Display & switch parameter automation in Edit window
#timesaver
Also applies to clicking the pan area (pan automation), volume (volume automation), mute (mute automation), send (send level). Carry over from what happens with a mouse click in Pro Tools.
Only slight difference is Ctrl+Cmd and double tap on the channel in the top horizontal bar to return to waveform (on Pro Tools, you just Ctrl+Cmd and mouse click the label of the track)
External Display for Mix/Edit window rakprachow Windows 2 10-26-2011 09:34 PM
Edit Window Display problem... Benjamino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-09-2010 11:03 AM
Shortkey command for mix/edit window switch meltra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-06-2009 01:10 PM
Midi edit window display ? Eddie K. wannabe MIDI 0 05-03-2003 07:58 PM
problem with edit window display spencer_davey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-04-2002 08:11 PM
