Old 11-05-2011, 06:28 PM
Camton Camton is offline
Default Need help with freezing
Heres my sandra report
< Processor >
Model: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
Speed: 3.4GHz
Cores per Processor: 4 Unit(s)
Type: Quad-Core
Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size, 2 threads sharing
L2 Cache: 2x 256kB, ECC, Synchronous, ATC, 8-way, 64
L3 Cache: 6MB, ECC, Synchronous, ATC, 12-way, Exclusive,
64 byte line size, 16 threads sharing
< Computer >
Mainboard: ASUS P8P67
BIOS: AMI (OEM) 2001 09/20/2011
Bus(es): X-Bus PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
Total Memory: 8GB DIMM DDR3
< Chipset >
Model: ASUS Core (Sandy Bridge) DRAM Controller
Front Side Bus Speed: 100MHz
Channels: 2
Memory Bus Speed: 2x 800MHz (1.6GHz)
< Memory Module(s) >
Memory Module: Corsair CML8GX3M2A1600C9 4GB DIMM DDR3 PC3-
12800U DDR3-1600 (9-9-9-24 5-34-10-5)
< Video System >
Video Adapter: NVIDIA GeForce GTX 560 (336 SM5.0 1.66GHz,
1GB 4GHz, PCIe 2.00 x16)
< Graphics Processor >
OpenCL GP Processor: NVIDIA GeForce GTX 560 (336SP 7C 1.66GHz, 1GB
4GHz)
Compute Shader Processor: NVIDIA GeForce GTX 560 (336SP 1.66GHz, 1GB
4GHz)
CUDA GP Processor: NVIDIA GeForce GTX 560 (336SP 7C 1.66GHz, 1GB
4GHz)
< Storage Devices >
WDC WD5002AALX-00J37A0 (500.1G:466GB (C:)
WDC WD5000AAKS-00A7B0 (500.1GB:466GB (E:)
HP DVD Writer 1270t (2.9GB, SA:3GB (D:)
< Logical Storage Devices >
System Reserved: 100MB (NTFS)
AUDIO (E:): 466GB (NTFS) @ WDC WD5000AAKS-00A7B0 (500.1GB,
SATA300, 3.5", 7200rpm, 16MB Cache)
WIN7 (C:): 466GB (NTFS) @ WDC WD5002AALX-00J37A0
(500.1GB, SATA600, 3.5", 7200rpm, 32MB Cache)
New York Concert Grand (D:): 3GB (UDF) @ HP DVD Writer 1270t (2.9GB,
SATA150, DVD+-RW, CD-RW, 2MB Cache)
< Peripherals >
LPC Hub Controller 1: ASUS P67 LPC Controller
LPC Legacy Controller 1: T0 C3-33
Audio Device: Giga-Byte 0E0Ch
Audio Codec: nVidia 0016h
Disk Controller: ASUS Cougar Point 6 port SATA AHCI Controller
Disk Controller: ASUS 91xx SATA 6G Controller
USB Controller 1: ASUS Cougar Point USB Enhanced Host
Controller #2
USB Controller 2: ASUS Cougar Point USB Enhanced Host
Controller #1
USB Controller 3: ASUS Renesas Electronics USB 3.0 Host
Controller
USB Controller 4: ASUS Renesas Electronics USB 3.0 Host
Controller
SMBus/i2c Controller 1: Intel ICH SMBus
< Printers and Faxes >
Printer: Microsoft XPS Document Writer (600x600,
Colour)
Fax: Microsoft Shared Fax Driver (200x200)
< Network Services >
Network Adapter: Realtek PCIe GBE Family Controller (Ethernet,
100Mbps)
< Power Management >
Power Supply No 1: OEM To Be Filled By O.E.M.
Power Supply No 2: OEM To Be Filled By O.E.M.
< Operating System >
Windows System: Microsoft Windows 7 Home 6.01.7601 (Service
Pack 1)
Platform Compliance: x64
< Windows Experience Index >
Current System: 5.9
I've just put this system together and everything seemed fine until it started freezing up. So far it seems to only happen when I use Kontakt with abby road drums.
I thought maybe it was the video card so I swapped out a sapphire ati Hd 5770 with the Nvidia card now....seemed better....till it crashed again.
I've done everything that was suggested with the win7 optimizations.
Also I set the timings for the memory in manual mode and all the drivers are up to date....bios, chipset driver etc.
I am wondering about maybe some other settings in the bios to change. I did notice something about BCLK/PEG that I can change for cpu and vga frequency settings.
I've been also trying to find a site that give more details for some of these bios settings.
Anyways any help would be great!
Old 11-05-2011, 06:30 PM
Default Re: Need help with freezing
Also forgot to mention that its Pro Tools 8.05 with Mbox 2
PT 10 freezing ericleed Windows 10 08-14-2012 02:19 PM
It's freezing out here Red Raven Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-01-2011 01:59 PM
Pro tools SLOW, and Freezing then continuing, then freezing again DJX-RAY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 07:52 AM
PT Freezing Up gregesme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2007 02:41 PM
Freezing! prodgod76 Digidesign Hardware & Software 0 11-18-2000 04:54 PM
