Old 09-07-2003, 09:36 PM
SonnyD SonnyD is offline
Default Help!!!To use phantom power on the Mbox....
...do I have to have a mic connected with an XLR? Does phantom power need an XLR connect mic to work? I have a condenser mic plugged into the Mbox with a 1/4 inch input. It's the sort of mic cable that goes from XLR (mic end) to 1/4 inch (mbox input). But i can't get a signal with the phantom power turned on. I've probably said too much but I just need an answer and I wanted to make my problem as clear as possible. Help?!?!
Old 09-07-2003, 09:40 PM
Default Re: Help!!!To use phantom power on the Mbox....
Yes, phantom will definately need a balanced XLR connector.. or you may very well damage the power supply as you'll be shorting one side to ground. Unbalanced microphone power would be called T power, and is usually 10 volts. Few microphones used T power, except for working with Nagra recorders.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-07-2003, 09:48 PM
Thanks You!!!!
Mbox Phantom Power - 2? jbmoony 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-12-2011 02:01 AM
Mbox phantom power issue ejwells 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-14-2006 03:37 AM
Mbox + Phantom Power Brubacher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-17-2004 12:09 AM
Phantom Power with the Mbox Josh Scanlan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-26-2003 06:41 PM
MBox-Phantom-Power? Ploch Klaus Pro Tools TDM Systems (Mac) 1 04-22-2002 02:12 PM
