Drive capacity limitations?
I've been trying to figure out if there's a hard drive capacity limitation for Pro Tools. I heard somewhere that PT10 could only see up to 2TB on a single hard drive. Is that right?
I'm considering an OWC Thunderbolt drive with 4TB (2x 2TB) capacity, and want to make sure that it would work. I tried the search function, and Avid's hard drive requirements, but don't see anything. Anyone know about this? |
Re: Drive capacity limitations?
Hi, I don't know for sure, but I've never heard this. I would think any hard drive space seen by the OS would be available for Pro Tools to use...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I am not sure why you need dual drives with a combined 4TB capacity, but you should avoid RAID on an audio drive. If you want seperate audio and sampel drives then leave those drives as JBOD. Last edited by Darryl Ramm; 07-08-2015 at 10:12 PM. |
Thanks for the responses!
I should have mentioned that I was planning to run the TB drive in "independent" mode (jbod?), so no RAID. Also, after thinking on it a bit, I'd be more likely to get the 2x 1TB versions. My thought was to run the first drive as my primary audio drive, and the second drive as a backup. I'd also have a USB backup drive I could keep off site when the project is finished. We're recording at 96k, and I'm guessing we'll end up with 700 GB of data when all is said and done. Any thoughts? |
G4 dual 1.25 CPU, hard drive capacity | mightyboy | Storage Subsystems | 0 | 03-24-2006 04:28 AM |
IDE drive capacity discrepancy | ProfessionalTool | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-12-2003 12:51 AM |
1622-192 legacy port? capacity/ limitations | rojo | Pro Tools TDM Systems (Mac) | 2 | 02-17-2003 12:17 AM |
large capacity firewire drive for video | COCO | Tips & Tricks | 2 | 01-27-2003 10:12 PM |
48 tk mix: drive capacity? | voravor | Storage Subsystems | 0 | 05-01-2000 07:04 PM |
