copying a whole section of 10 tracks and pasting?
Hey All,
Ok..I've got like 10 tracks, and I've already recorded a chorus that is done. I want to repeat the chorus again, but don't wanna have to re-record everthing..so i was thinking.. can i just copy and paste a section of the 10-piece track block of those certain parts..like if i highlight them or something? Well..I did that. I selected from the bottom and highlighted the part all the way up to the top, right? ..then, i scrolled to the right and tried to paste when i clicked in the very top track, but it only pastes in the top block, not all the blocks! sucks. how do i paste the whole thing..every piece that i selected? know what i'm sayin? |
Re: copying a whole section of 10 tracks and pasti
Hmm, how do I explain this...
First off, make sure the tracks are "back-to-back" (as opposed to all spread apart) AND, most importantly, make sure you're in grid mode. After you highlight and copy the section of tracks you want, then go to where you want it to play again. When you select that spot, drag down until the cursor highlights all ten tracks. Now paste it. Also, you can create a region group and drag it out of the list to where you want it to go. That's the easiest way, but I can't recall if it's only available in version 7. Also, if the part comes right after the last part, you can just repeat it (atl+R). Not sure if I explained it right, as lots of stuff I just do now without thinking, but it's pretty easy to do. Peace |
Re: copying a whole section of 10 tracks and pasting?
.. or simply use an Edit Group.
Rail
Make sure the cursor is blinking in ALL the same tracks (10 in your example) you copied from.
It's easier (and faster) to create a group with the 10 tracks, then trun the group off or delete it when you're done. Ter |
ok cool..the grid thing works great! thanx
Copying and pasting regions | wgouldsby | General Discussion | 2 | 01-14-2013 03:14 AM |
problem copying and pasting | killionaire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-30-2009 12:07 AM |
Copying and pasting in the workspace | meathman | Post - Surround - Video | 0 | 07-14-2007 12:08 PM |
Copying/Pasting Multiple Tracks at a Time | KMAN385 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-30-2007 02:23 PM |
Looping and copying and pasting | Mikchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-17-2003 08:53 AM |
