Using Templates
In PTLE 6.7 I am trying to make sessions easier. I know there is a thread out there somewhere on this topic. Can someone point me in the direction?
In Sonar I had a midi template, Midi+audio, and Audio only template. I also had the plugs set-up for these templates. I would open one up save as (new session name) and get after it. Do you guys also have redundant session EQ, Rev, Gate and comp settings? Thanks
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
Re: Using Templates
Start by creating a session with all the tracks and assignments you want(set for your desired sample rate/bit depth and enforce mac/pc compatibility if its there) and save it somewhere easy to find. When its closed, right-click on it>select properties?select "read only". Now you won't mess it up by accident. When you want to start a new session, create a new session on your audio drive with the same sample rate/bit depth>name it and hit enter to open. Now go to File>Import Session Data>select your template session and hit enter. Your new session will now have all the settings/tracks/plugins of the template.
Re: Using Templates
Thanks for all of the help Allbe. Good to hear from someone tonight.
Templates!!! | juca2929 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-24-2008 01:44 PM |
Templates | Brad Newman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-19-2007 05:58 PM |
templates in PT7 | 8thnote | Pro Tools TDM Systems (Mac) | 4 | 05-16-2006 12:40 PM |
Templates | BenTerry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-13-2004 08:37 AM |
OMF bug using templates !! | Helgonet | Pro Tools TDM Systems (Mac) | 8 | 12-10-2003 03:56 PM |
