  #21
Old 12-11-2018, 01:42 PM
ehaber ehaber is offline
Default Re: Real time SR conversion via spdif - Avid HD IO
By the way, regarding the post that recommended the MTRX (which is a great unit), for sample rate conversion, the MTRX is similar to the HD I/O; that is the chassis digital I/O that come with the MTRX (16 channel of AES, coax MADI, Dante if you have a Dante card) do not have SRC; while if you separately purchase and install a slot digital I/O AES, MAdi, or (the new) Dante card, those slot I/O cards do sample rate convert.
  #22
Old 12-11-2018, 08:37 PM
Eric Lambert's Avatar
My HD IO does in fact have a digital card installed into one of the expansion slots. It looks like this:
https://www.google.com/url?sa=i&sour...44675690398949
Shouldn't I then be able to get realtime SRC with that card? I'd try it now, I'm just not currently equipped with the proper DB25 cable nor the spdif-to-AES adapter.
  #23
Old 12-11-2018, 09:32 PM
Yes. Edit: Ah but... the photo you link to is a 192 IO digital card, that won't work in a HD I/O. I hope you have the actual HD I/O version of a digital card.
So hoping you have the HD I/O digital card all you need is one of these...
https://www.bhphotovideo.com/c/produ...Data_Link.html I'd much rather do that than try to just use an analog cable with balun in it.
You should be able to wire up a XLR to a DB-25. Much cheaper then buying a cable if you just need one connection.
But here is the cable if you want to buy one... https://www.sweetwater.com/store/det...gisnake-4-foot
If you buy another brand DB-25 cable set make sure it's wired for the TASCAM/Avid standard.
https://www.sweetwater.com/sweetcare...-pinout-guide/
  #24
Old 12-11-2018, 09:41 PM
Top Jimmy's Avatar
Originally Posted by Darryl Ramm View Post
If you buy another brand DB-25 cable set make sure it's wired for the Yamaha/Avid standard.
Doesn't Avid use the Tascam pinout?
James Cadwallader
  #25
Old 12-11-2018, 09:43 PM
Doh I transposed it in my head. Edited my post to fix.
  #26
Old 12-11-2018, 11:07 PM
Yes, I have the HD IO card.
  #27
Old 12-12-2018, 08:13 AM
Originally Posted by Eric Lambert View Post
So... anyone know of a small, external, high-quality sample rate convertor?
(but seriously, I do need one)
Hi Eric - not particularly small (1 rack unit), but I've got a Behringer SRC2496 box that's been gathering dust here for as long as I can recall - I bought it for some particular task years ago and haven't used it since - honestly, I'd give it to you free if you picked it up.
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
  #28
Old 12-12-2018, 11:38 AM
Wow, Rich, that's quite generous! I'll email you. Thanks!
  #29
Old 09-01-2020, 04:04 PM
dsumich dsumich is offline
Hey guys, found this old thread. I have the exact same issue. I have the Digital I/O card installed in my 96 HD I/O, but not sure how to utilize it. Would I just use a cable to run from the s/pdif output of the OX to the optical s/pdif input on the expansion card of the I/O? Something like this?
https://www.banggood.com/CE-LINK-5M-...r_warehouse=CN
If that happens to work, do you have to do anything to kick in the SRC, or does it happen automatically?
  #30
Old 09-01-2020, 04:38 PM
Never mind this question. I think I understand from Darryl's post above you need the converter from s/pdif to AES/EBU, and then run that into the DB25 digi snake cable that connects to your digital i/o card. I will get the two products linked to above (seems to be about $200 for both these days) and report back how it goes. I am guessing though you still need to turn on SRC in the Hardware Setup Dialog on the Digital tab for which ever channel pair you are i/o'ing on.
Spdif RCA to Spdif Optical conversion - degradation?? Hollow Body 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-17-2011 08:21 AM
Real-Time Bounce to Disk...REAL PAIN Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 201 07-26-2010 08:12 AM
File Conversion-W/O real time play down STUDIO 44 Pro Tools TDM Systems (Mac) 4 08-26-2005 01:54 PM
real time Sample Rate Conversion nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2004 06:46 PM
Capture range for real time SR conversion KK Proffitt Pro Tools TDM Systems (Mac) 0 10-19-2004 01:44 AM
