Old 07-30-2012, 01:23 AM
LukeFromBerlin LukeFromBerlin is offline
Default Max Temperature Avid Hardware / Interfaces ?
I've searched Avid's tech spec's, manuals etc ...but couldn't find an answer:
My hardware is in an extra room and although I built some sort of ventilation for it, its becoming more and more hot in there (3 x HD Interfaces, 2 Macs, Surround-Amplifier etc....).
Any guesses aproximally how hot I can allow it to get - without me having to worry about drastically shortening the lifespan of my HD rig or risking some electronic parts to die ...etc ?
Right now on a hot day it can be 104 Farenheit (40 Celsius) in there ... Absoltuely no problem - or do I have to worry and better improve my ventilation-system immediately ?
Thanx for advcice !
Soft: ProTools 8.1
OS-X 10.6.8
Hard: ProTools HD 3, PCI-e core & accel, 96 I/O, 192 digital I/O, HD MADI / Sync I/O (not sync HD)
Quad-Core Mac, Intel
Old 07-31-2012, 02:44 PM
maxtn maxtn is offline
Default Re: Max Temperature Avid Hardware / Interfaces ?
I know of no electronic equipment with room temp. specs. over 100 degrees F. In fact the 192 I/O is 95 degrees F. The internal temp is much much greater and most computer/equipment rooms are cooled to 65 degrees F.
My humble opinion is you are asking for trouble. I have mine cooled to 65 and it has run 24/7 for 7 years.
M
System#1
PT 10HD Harpertown Lion
HD4 Accel Magma PE6R4-I
Motu PCI-424e
ProControl 32 Faders
System#2
PT 11 and 10.3.6 2012 Westmere Mountain Lion
HDX
MC Mix - MC Control - MC transport - MC Mix with Command 8
Old 08-17-2012, 07:26 AM
Thank you Max !
I appreciate your advice (finally someone could give me some info on that issue !)
Already checking options for a cooling system ...
Soft: ProTools 8.1
OS-X 10.6.8
Old 08-17-2012, 03:55 PM
phatbeatstudio phatbeatstudio is offline
That is a good question I have been thinking about as well.
I have a tube pre with a 2 space gap under my HD interface and it became very warm indeed. I don't use that pre now because I am wondering the same thing. It gets to warm for sure where it is I guess I need a new rack before I can power that up again . Im not going to ruin my best converter over lack of rack space.
I only made a comment on this thread to bump it back up ,incase somebody has a more detailed answer for you.
Old 08-21-2012, 06:57 PM
Jeff D. Jeff D. is offline
I've had mine in my Southern California desert garage for 5 years... gets to over 100 degrees F everyday for 2 months in the summer, sometimes over 110 degrees F. No problems yet.
www.jephthastudios.com
Excessive Processor Usage and Temperature: Avid 002 & 003 Family Driver Mike Harrison macOS 10 08-15-2014 02:54 PM
Unable to locate Avid hardware. Avid Pro Tools SE 8.0.3 (M-Audio KeyStudio 49) azndisast3r Pro Tools SE and Essential (Win) 3 09-21-2013 02:31 PM
Traditional Avid interfaces vs 3rd party interfaces aftermid Pro Tools 10 9 10-24-2012 01:12 PM
New Avid M-Audio Interfaces M-ManLA General Discussion 0 10-06-2011 12:36 AM
Will PT HD 8.1 work with the new Avid HD i/o interfaces? rcd Pro Tools TDM Systems (Win) 1 09-27-2011 10:54 AM
