Control 24 main monitors phasing/dropping hf
This is a problem that seems to be random, not caused by anything predictable or repeatable. It happens in both speakers, but never at the same time. It seems like the high frequencies are dropping out occasionally on one speaker or another, or randomly phasing. it usually only happens momentarily and then comes back or occasionally the dropout lasts for a few seconds. It's annoying and I want to fix it. I haven't noticed it on my alt monitors yet either.
Maybe DigiTech support will chime in Has anybody else had this same problem? I have owned this board since new and have been very happy with it up until now, actually I remain happy with it so I just need to correct the problem. I would like to know a) if anybody has dealt with this. B) what the problem was/is. C) what needs to be done to fix this. I'm hoping it may just be a harness issue or at worst some failing caps, but I wanted to check here before I opened it up. |
Re: Control 24 main monitors phasing/dropping hf
I'm still having this problem, it occurs on the main and aux monitor channels and it's getting worse. Has no one ever dealt with anything similar?
The problem is that the audio is digitally controlled and routed between the 192 output and the speaker outputs. The board was not easy to replace and required so much other stuff to be removed to get to it, but if you are confident/competent at this sort of thing and take lots of pictures as you disassemble it then you'll be fine. I Hope this helps Lizardpoint |
Im having problem with the lowed just the same.
But Im using a HD Omni now and it is still doing it. When I solo a track the lowed is not the same from one speaker to the other. Iv even sent in my monitors but its not the monitors at all its something else. |
This will prove its within the Control24. Lizardpoint |
11Rack no main Input Signal through monitors | dood | Eleven Rack | 10 | 10-12-2012 11:36 PM |
Digi 002 Main Outs vs. Monitors, which do you use? | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-13-2010 01:14 PM |
Machine Control Dropping ICON | laki | ICON & C|24 | 0 | 09-02-2010 07:09 PM |
Phasing Main Title Music on the Daily Show | MX | General Discussion | 4 | 07-24-2005 03:21 PM |
Help...Monitors are dropping in and out. | Josh K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-27-2004 05:18 PM |
