Old 03-07-2016, 09:27 AM
bmstone bmstone is offline
Default Command 8 PSU Pinout
Looking for the three pin wiring pinout for the command 8 power supply. Yep... I need to build one. Thanks
Old 03-17-2016, 06:02 PM
Default Re: Command 8 PSU Pinout
Well. Despite my best efforts, I never could get an answer. However, I did figure it out on my own. I purchased a 50VA toroidal transformer with dual primary and secondary windings. After reading reactor's post about using a similar winding with the secondaries wired in parallel I decided to duplicate the vague reference. Building the transformer was the easy part. Not being able to verify the voltage to pin requirement was the challenge. Without any additional references, I decided to disassemble the motherboard for clues and bingo! I discovered two slow-blow fuses on two legs (12Vac each) and a circuit trace acting as the neutral. I didn't want to risk burning anything out so I isolated one of the windings, to prevent the 24Vac differential, and powered both circuits from a single winding. Voila! The C/8 powered up without any problem and has been operating very well. Hope this helps somebody...
Old 03-17-2016, 06:14 PM
YYR123's Avatar
YYR123 YYR123 is offline
Just saw this sorry....
Daniel
HTML code is On
FOH link Pinout? C Hawk VENUE Live Sound Systems 3 06-06-2010 04:54 AM
db25 PC pinout GrantFM ProControl, Control|24, Command|8 3 10-09-2009 11:24 PM
Old Shure Unidyne Model 545, pinout to XLR? guitar486 General Discussion 9 02-11-2009 03:16 PM
pinout config. blue demon ProControl, Control|24, Command|8 1 02-24-2004 09:01 PM
MachineControl Sony pinout 9-pin Busshart Tips & Tricks 0 09-19-2000 01:57 AM
