Old 03-18-2013, 06:32 AM
alidav alidav is offline
Default "combining" two pt session into one
i edited a dialogue in one session and now want import related session into a new session, is it possible?
Old 03-18-2013, 06:38 AM
Meads Meads is offline
Default Re: "combining" two pt session into one
Yes, via import session data. There are various options, pick whichever you need.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 03-19-2013, 05:11 AM
Originally Posted by meads View Post
yes, via import session data. There are various options, pick whichever you need.
do i need to export an omf?
Old 03-19-2013, 05:15 AM
crizdee's Avatar
crizdee crizdee is offline
No, you can use any Pro Tools session that is saved as compatible with your version. but you can also import session data from OMF and AAF files.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-19-2013, 06:25 AM
I am using pt 10, have just finished to edit a dialogue, and saved the session, now want to import that 4 track session in another project, without doing any bounce at all, what is right thing to do ?
Old 03-19-2013, 06:28 AM
Open the other project, file -> import -> session data -> choose the dialogue edit session.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 03-19-2013, 06:43 AM
ok ok i see it now
Old 03-19-2013, 01:19 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Or If you have yopur PT session you want to import the other session intp open... then just open a window that has the session in it with those 4 tracks and drag it into your timeline... this will automatically pop up the import session data screen and already have that session you dragged in selected as the data to import... select what you want and click OK...
Just bypasses the need to go up select import data then find the session then select what to import, etc...
Cuts out a few steps.
Old 03-19-2013, 02:28 PM
audiobob's Avatar
audiobob audiobob is offline
Holy crap...I just learned something today.
Old 03-19-2013, 02:45 PM
I accidentally dropped a session into a project one day and realized the drag and drop features in PT... You can also drag other things into other areas for different importing... like a track (audio file) can be dragged into a track right from your OS window (ie, finder, windows) or you can import it to your clip bin (instead of going up and selecting import audio you just drag)...
There are some more things like this that you can look up online and dragging things into various parts of PT does different things.
It has saved me a ton of time over the last couple years
"Compiling" multiple sessions into one "Master" session. Any pointers? Nollykin Tips & Tricks 17 12-09-2013 10:36 AM
Difference between "Go to Song Start" and "Return to start of session" shortcut pericoloso Pro Tools 10 2 09-22-2013 12:44 AM
"Pro Tools not responding" error and a very "laggy" session! Help! drumbumd Pro Tools M-Powered (Win) 0 02-10-2012 05:37 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
