Old 12-29-2012, 02:34 AM
malmalibu malmalibu is offline
Default No sound from Beats audio system on board HP Pavilion DV7 Laptop
Pro Tools 10 asio4all HP Pavilion no sound
I have put Pro Tools 10 onto a HP Pavilion dv7 with beats audio and installed asio4all v2 I get "no sound" from the laptop's on board speakers? tho I do get sound from head phone jack through head phones. Pro tools is playing the project ok. The project was recorded and mixed on a Toshiba P300 with pro tools 9. Both laptop's have a m-audio fast track ultra 8R digital audo interface installed on them and they both record and play back fine when the m-audio i/o is used. Initiall I did have problems getting audio from speakers and head phones on Toshiba tho I did finally get the audio to play on the Toshiba's onboard speakers and Head phone jack and could do the mixdown fine using just the Toshiba when i select the asioall i/o. I did have the "no audio problem" initially with the Toshiba untill i change some of the settings in the asio4all control panel. I have not had the same luck on the HP laptop. Both laptops run windows 7 the Toshiba is 32bit and HP is 64bit Both have 2 hard drives. Is there any chance that there is a solution to "no sound" on a HP Laptop on board Beats sound system??? Any advice would be appreciated Cheers
Norman A Hamley www.malibugroove.com & www.timelessrocknroll.com
Old 08-29-2013, 06:20 PM
Default Re: No sound from Beats audio system on board HP Pavilion DV7 Laptop
Have found a fix that has worked for this issue
See thred http://duc.avid.com/showthread.php?t=343763
Cheers
Pro Tools 10 asio4all HP Pavilion no sound malmalibu Pro Tools 10 1 08-29-2013 06:22 PM
how do i switch sound fro integrated laptop speakers to audio interface?? thanatas007 Pro Tools 10 5 09-06-2012 11:13 AM
Looking for help on PT8 on HP Pavilion laptop chicm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-04-2012 06:03 AM
Mbox2 Mini and HP Beats Laptop takieddo Pro Tools 9 2 10-02-2011 05:26 PM
HP PAVILION DV7-1285DX Laptop Question RichrdC Pro Tools M-Powered (Win) 2 12-05-2009 10:27 PM
