Old 08-20-2010, 10:45 AM
BJohnston BJohnston is offline
Default Pro Tools HD 8.0.4 Huge Record Mode Delay
I have made the upgrade from PTHD 8.0.3cs to the new 8.0.4 because I've been having issues being able to record into PT. When I arm the track and push play/record I get the spinning wheel and it takes about 1-2 full minutes before it actually starts recording. The upgrade did not fix the issue. I can open up other sessions and record just find, but it seems as though certain projects have issues. I've tried making new templates and importing the same wave files and same thing keeps happening.
Any thoughts or suggestions would be greatly appreciated!
B
System Setup:
Mac Pro OSX 10.6.4
Memory: 13 GB 667 MHz DDR2 FB-DIMM
Internal HD 250 Gigs...of that I've got 30+ Gigs free
Pro Tools HD 8.0.4
Old 08-20-2010, 10:55 AM
formfunction formfunction is offline
Default Re: Pro Tools HD 8.0.4 Huge Record Mode Delay
Have you tried using "import session data" to create a new session. Sounds like you are using import audio.
And try deactivating all your plugs and see if it still happens. (incompatible plug) Either of those will send you in a positive direction, I think.
What other troubleshooting have you done? ff
Old 08-20-2010, 10:57 AM
nanoweber nanoweber is offline
Setting the maximum record time (allocation) in the prefs may help.
Old 08-20-2010, 10:59 AM
just realized....if you're using the boot/system drive that could be the problem.
Old 08-20-2010, 01:26 PM
I've tried both importing audio files and importing session data.
Not sure what you mean by boot system drive?
Old 08-20-2010, 01:40 PM
Did u do the plugin thing?
Old 08-20-2010, 06:41 PM
I will try the plug in thing tomorrow. Thanks for your help!
Old 08-21-2010, 09:58 AM
I've officially tried the deactivating all plug ins. Didn't help.
Old 08-21-2010, 10:00 AM
I checked that out as well. It is selected for Maximum Record Time. Still nothing.
Old 08-21-2010, 10:02 AM
drBill drBill is offline
Set it for 20 minutes and try again.
Huge delay when sending from a channel which is record enabled to an external send Thirtythr33 macOS 2 07-28-2013 01:03 PM
30 Second Delay when Hitting Record - Pro Tools Le 8.0.3 xesands macOS 11 03-24-2013 11:25 PM
Pro Tools 10/Mackie Onyx white noise in record mode benbeer macOS 3 02-21-2013 07:27 PM
Reel tape delay - HUGE cpu hog! Stiff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-02-2007 02:45 PM
Huge Delay to 5.0.1 splash screen potatohead Pro Tools TDM Systems (Mac) 3 08-11-2000 12:27 AM
