Old 03-05-2016, 02:49 PM
fmo fmo is offline
Default pops and clicks in offline commit tracks
Am having problems committing tracks in 12.3 - working on a project with about 40 tracks of VIs, mostly eastwest.
Was all going well, cores all around 12% - cpu less than 50%. Then today pt was crashing repeatedly with 9173 errors - restart not helping, nor using previous saves.
tried to commit in real time - crashed with 9173. Tried to commit 20 tracks only - crashed again.
Then did offline commit which worked, so deactivated the midi tracks, then found many of the committed audio tracks had clicks and pops, also sounded flatter when comparing directly to their respective original VI tracks (which I reactivated one by one to compare)
Then tried to commit just a sole track to compare again - the same clicks/pops. Experimented with different disk cache & buffer sizes - no success - either the whole session crashes, or the committed tracks have noise issues.
Still experimenting, but would really appreciate any suggestions as I can't now progress on the project. Thanks in advance for any help.
MBP 2.5GHz core i5, 10.10.5, 16gb ram, PT12.3, m-track quad, arturia keylab, e/w cloud composer, analogue lab, ni, bluecat, sound machine.
Old 03-05-2016, 02:56 PM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Default Re: pops and clicks in offline commit tracks
Grab this and trash your preferences. After you set them up again, save them using this app.
http://www.pro-tools-expert.com/home...gain-now-v1610
Hope this helps.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 03-06-2016, 09:00 AM
kurt's Avatar
kurt kurt is offline
ASAP!
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 03-07-2016, 03:23 PM
fmo fmo is offline
Thanks for that Ron. That app didn't help this time but no doubt it will one day! Got there in the end after much trial and error. I think it was a combination of many VIs, within multiple instances of the eastwest play engine and pushing the limits of a fairly underpowered system.
Offline commit no use at all when streaming samples - all the long notes, particularly brass, would produce pops and clicks when not committing in real time.
So had to commit real time - and PT crashed whenever I tried to commit more than one ew Play engine (containing about 9 tracks/instruments) at a time.
Eventually did four real time commits, while making all other tracks inactive each time. There was still the odd track that glitched, but was ok once committed by itself.
Laborious process though, if anyone can suggest a better workflow then please do. Also, the Eastwest play engine has a streaming engine level control. Can anyone recommend an optimum setting for that for my system please? Am currently streaming from eastwest's own supplied 7200 usb3 drive. Would adding an ext ssd to this system make much difference?
Commit Sound Quality - or is it offline bounce? JKR Pro Tools 12 4 11-09-2015 03:08 PM
Fixing a few Clicks & Pops on tracks? pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-30-2004 02:01 PM
Clicks/pops in recorded tracks soundshedstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-25-2004 01:54 PM
HELP! - Pops and clicks on record-enabled tracks Spitshine-Drums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-18-2004 10:20 PM
Need Help! – Clicks and pops on Continuous Tracks vitaming 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-29-2001 09:25 AM
