Old 06-19-2010, 08:29 PM
Daedalus77 Daedalus77 is offline
Default BFD 2 and Multiple Outputs
Hi, all—
Anyone know how to set up a session so that each kit piece in BFD 2 gets routed to its own Aux return within PT for individual processing?
I know how to set things up within BFD 2: each kit piece (and ambient mics) go to one BFD's internal mono or stereo busses.
But how do I get each one of those routed to it's own Aux input within the PT session?
Thanks,
David
Old 06-20-2010, 01:45 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: BFD 2 and Multiple Outputs
Originally Posted by Daedalus77 View Post
Hi, all—
Thanks,
David
Use "BFD Multi" then the outputs from BFD will show up on the inputs of aux and audio tracks
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-20-2010, 06:54 AM
That's the thing...
When I used BFD 1.x, there the "BFD Multi" was an option in the plug-in (insert) drop-down menu, with BFD 2, there is only a "BFD Stereo" option.
According to the FXpansion folks, this is the only option with BFD2, but one can still route the outputs of individual drum channels to separate channels in PT by treating BFD 2 as an instrument with multiple outputs.
Others?
Many thanks.
Old 06-20-2010, 08:49 AM
WernerF WernerF is offline
So treating it as an instrument with multiple outputs doesn't work? Just trying to understand what you mean.
Old 06-20-2010, 09:01 AM
dwaynedelario dwaynedelario is offline
David,
I believe you have to go to the mixer page within BFD2 and change the outputs from "Master" to either mono1 mono2 etc, or stereo 1, stereo 2 etc. Then on the input side of your aux tracks BFD's plugin inputs should begin to show up.
Have you already done that?
-Joe
Old 06-20-2010, 09:04 AM
And here you go... found this little gem on the web:
http://www.obedia.com/blog/index.php...-in-pro-tools/
Old 06-20-2010, 10:02 AM
Awesome. Many thanks, all.
mix to multiple outputs scottpetito Pro Tools TDM Systems (Mac) 0 05-13-2008 04:37 AM
Multiple outputs beelzebub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-29-2007 10:00 AM
Multiple Outputs? Digitalkidd Virtual Instruments 9 02-19-2006 05:36 PM
Multiple outputs for multiple players. KingFish ICON & C|24 1 05-08-2004 01:13 PM
Multiple outputs MaizeBass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-22-2002 07:58 PM
