Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 10-27-2020, 02:12 PM
Default Re: Feature request: Mixer window should have a wider maximum width
I hope so, as this does affect my workflow sometimes. However, there seems to be more people screaming about the inability to bounce to QuickTime on OS X Catalina for now. "The squeaky wheel get the grease" as they say.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 10-30-2020, 07:01 AM
MixerGuy MixerGuy is offline
There is no reason we cant have both fixes at the same time.
It isn't one fix per update. not at all.
Old 11-02-2020, 09:38 AM
daeron80 daeron80 is offline
To me, it's weird that PT still has hard track limits. But given that it does, it's bizarre that its own design makes it impossible to see the number of tracks it allows.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 11-02-2020, 06:12 PM
SDDP SDDP is offline
Ideally, it would be great if we could have the option to have track width of the mixer as the same as in the edit. Folder tracks helped TREMENDOUSLY for mega large 5.1 sessions, but it's either narrow or normal for the mix tracks. Would love to narrow all of the subs, splits, etc and keep the other audio tracks at normal or make some micro or mini. can't they just copy the code from the edit and and apply it to the mix tracks?
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
Old 11-27-2020, 11:00 PM
Originally Posted by MixerGuy View Post
so actually this should be more of a BUG report. Not a feature request.
Hopefully they are working on this.
update - still broken in 2020.11
  #16
Old 11-27-2020, 11:36 PM
JFreak's Avatar
JFreak JFreak is offline
Just my opinion, but any window should not have maximum dimensions other than that of operating system may have
Janne
  #17
Old 11-28-2020, 07:36 AM
I dont know what you mean.
my computer can handle the size of monitor attached to the computer.
it happily shows a desk top image of that size and ratio.
so clearly the operating system can handle it.
so too should ProTools mixer window.
  #18
Old 11-28-2020, 07:42 AM
JFreak's Avatar
Just that. In case there is some fixed number that limits PT window to max width it needs to be removed. It has to be OS that limits window dimensions.
Janne
  #19
Old 12-04-2020, 01:24 PM
so is there a way to submit this as a bug report, to avid?
  #20
Old 12-04-2020, 07:44 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Originally Posted by albee1952 View Post
You mentioned narrow view, but there is a 3rd option that is undocumented. If you use the "fat meters" hack while in narrow mix, it actually creates a compromise where the tracks are wider than the typical "narrow" view, but not as wide as normal. That's the setting I use all the time(the hack being hitting all 3 modifier keys and clicking on any track meter in the MIX window).
I must correct you. This feature is actually very well documented on page 748 in my new book "Pro Tools 2020 - How it Works"
http://dingdingmusic.com/-titles-/pr...-it-works.html
Here is a screenshot that shows the four variations between Wide-Narrow Channel Strip (op+cmd+M) and Wide-Narrow Meter (ctr+opt+cmd+click).
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Maximum width of Edit Window? bad jitter Pro Tools 2019 15 07-25-2019 02:39 AM
Pan window in 5.1 feature request... JR Fountain Artist Series 1 03-03-2011 08:59 AM
PT feature request, mixer A/B button James Drake Pro Tools TDM Systems (Mac) 2 02-19-2007 08:05 AM
Feature Request - Bus Mixer Andre Knecht Pro Tools TDM Systems (Mac) 7 02-01-2007 05:21 PM
Feature Request-stacked mixer view Drew Mazurek Pro Tools TDM Systems (Mac) 1 01-08-2005 01:36 PM
