Mbox wordclock sync?
I can't find any documentation on this. Since the SPDIF port carries wordclock, can the Mbox by synched with other devices such as CD burners which have wordclock inputs? Do I need a SYNC box from digi or something like Nanosyncs?
************ Steven Vertel Mixing / Mastering Engineer High Rock Records & Studio NYC http://highrockrecords.com |
Re: Mbox wordclock sync?
Bump
OK, let me elaborate and hopefully someone smarter than me can weigh in: I know that I can connect the Mbox to a Benchmark DAC-1 and set Pro Tools to sync to the Benchmark. What is unclear to me is whether or not there is a way to sync additional items such as a CD burner or digital EQ to the Benchmark's clock. Can s/pdif be daisy chained for clock sync??
I'm confused on how the DAC-1 would sync up ProTools. Being a digital to analog converter, does it have digital outs, also? I know it has a complete selection of digital ins with XLR's and RCA's on the analog output side. If there's a digital out I can see how you could use the DAC's better clock.
You can daisy-chain a few s/pdif devices as long as the first is a well-clocked device connected via s/pdif to everything else (set to digital external clock and able to pass it on via s/pdif). Problem is, all the devices have to be on and properly set up for it to work. The coolest set up is to have a master clock device with multiple digital outputs feeding each device, or wordclock (if usable) distributed to everything with ProTools synced to something via s/pdif. MR
Learn to listen. Listen to learn. |
Sync, wordclock issue | mixmania | Pro Tools TDM Systems (Mac) | 3 | 06-02-2011 07:57 PM |
Wordclock sync via SPDIF with any interface? | nucelar | Pro Tools 9 | 3 | 04-18-2011 08:49 AM |
PT Sync with wordclock | mongiver | Pro Tools TDM Systems (Win) | 1 | 02-10-2004 05:56 AM |
MTP vs DTP and spdif wordclock sync to 001/PTle | rdatman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-22-2002 12:33 AM |
Question regarding Wordclock sync... | chengod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-16-2002 10:13 PM |
