Pro Tools channels clipping info
Hello there,
How can I get the channel to clip again like it used to do in the old days, where it hit red and clipped? Also, was it hard or soft-clipping? Thanks in advance :) |
Re: Pro Tools channels clipping info
You can't without the old TDM hardware with its fixed-point processing.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
assign to an output and bounce to 24bit.
I am reminded of a Darrell Scott song "The good ole' days are just good an gone"
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1 Enjoy the Journey.... Kev... |
Meh that sucks, I would've liked to create a gainstage related clipping system because with Lofi you can only tweak it to the inserted source, where I'd prefer something more streamlined, like on an SSL where you EQ into something and it clips at a certain point...
Use any variety of analogue modeling channel strips and “clip” there. Tons of companies make them (including modeling the SSL desks.) The SSL is an analogue desk so clipping can be euphonic. Internal ProTools is a hard digital clip when you hit it. Nothing nice about that.
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Hi atticmike, you might like the feel of having the old AIR Distortion plugin parked on the ends of all of your channels. (It's included in… all versions of PT? I'm not sure on that, but it's been included in PT Native since 10 at least). Set it to hard clipping, lower the drive down to 0dB, raise its "ceiling" to 0.0dBFS, and it will be totally transparent up until you hit the rails in terms, which should be just like the old TDM systems in feel if not necessarily in technical terms.
That should be the easiest (and cheapest!) way to get that old school PT feel. You can also try setting it to soft clipping, which would be less true to the old PT mixer sound but could be cool in its own way, but be aware that even with zero drive the soft clipping mode of AIR Distortion adds a bit of gain, like two or three dB. If you want to try using it in soft clipping mode you would probably want to insert it at the ends of all of your channels before you start mixing, so that you can "mix into it," rather than dropping it in halfway through a mix and having to pull all your faders back to compensate for that level boost. As someone who has spent silly money on fancy third party saturation plugins, I still use AIR Distortion maybe every other mix. IMO it is a very underrated little plug! |
Edit window visual clipping and audio clipping question... | Jakay | Pro Tools 11 | 4 | 07-22-2015 06:52 PM |
Pro Tools 7 TDM Plugin Clipping | atticmike | Pro Tools TDM Systems (Mac) | 17 | 04-05-2015 11:01 AM |
Pro Tools 9 Plug In Clipping problems | Avocado Baby | Pro Tools 9 | 2 | 04-06-2013 04:58 PM |
Normal Levels from Pre amp, Clipping Pro Tools | tbystedt | macOS | 0 | 03-03-2013 05:36 PM |
Pro Tools not indicating clipping | RhysC | Pro Tools M-Powered (Win) | 2 | 10-13-2010 10:40 PM |
