I/O Set-up Issue
Getting started with a MacBook Pro and ProTools 11.0.3. Have a MBox Pro 3 interface. The I/O Set-up window shows {Built-in Microphone 1-2} L R for inputs 1 and 2. In creating a new mono audio track, the Built-in Microphone also
shows up off the bat. There's also {Built-in Output 1-2} in the I/0 Set-up map and the track. Mbox Pro shows at top of map spread over all Inputs & Outputs on those two tabs. Long and short of it is: can this Built-in Mic and Output business be removed so it doesn't show up anywhere. I'm using an Mbox Pro, NOT the built-ins. Please advise. Thank you |
Re: I/O Set-up Issue
Check your playback Engine
If it doesn't say Mbox then change it, then hit Default button on IO while holding Option key to set up the default I/O Busses etc for that engine and interface. Video: IO Setup - Quick Trick 1 |
Thank you so much, Ceri. Had already changed to Mbox in the PlyBk Engine. It was the "while holding the Option Key" when pressing the Default button in IO that did it. Now my
I/O Setup map is all neat and tidy with MBox stereo analog pairs 1 thru 6, and SPDIF L/R--and no "Built-ins" |
I'm having this same issue but the internal inputs remain after loading the 002's defaults in the in/out pane. Tried deleting the internal paths and adding new paths named Analog 1-2, 3-4 but the new path doesn't get recognized. What am I missing here?
Thanks, RockGad |
Figured it out. Thanks.
Hi rockgad !
Can you post how you resolved it please ?
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
THANKS A MILLION also one freaky thing too?, I just got my ADL back from Presonus and now I'm hearing a screeching noise on different inputs. Man I hope the mod they did isn't the problem. Had them correct the impedance jumpers settings, mine was one of the older units with the incorrect jumper settings. Also the video link is dead?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
I tried hitting default with the option key pressed, still not right on the inputs, the outputs are correct, but the inputs are not on my 003 console.
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue | ZDF | macOS | 0 | 01-14-2013 02:47 PM |
weird crash issue PTx and possible procontrol issue, need help | Cryos | Pro Tools 10 | 5 | 12-08-2011 05:17 PM |
Some regions had invalid bounds... non-issue becoming a crash issue!!! | krichu | Pro Tools 9 | 3 | 12-11-2010 04:49 AM |
Digi 002 Power Harness Issue or Firewire Chip Issue? | Nish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 05-07-2010 01:25 PM |
002 Console Issue, Faders Wont Move (grounding issue?) | guitar486 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-01-2010 03:58 PM |
