11R expansion pack firmware not updating Win7 64
Hello to all,
Sorry to bring this up again, but I just can't seem to get this to work. Bought a 2nd hand 11R and pro tools 8 le. installed pro tools and updated to 8.0.5, bought expansion pack, tried to install, firmware update keeps failing. have been through several uninstal and re-instals of pro tools to no avail. have uninstalled ie9 and ie 8, so no ie at all, no joy. Can connect with the 11R in pro tools and see amps and can even see the new amps and cabs but not the effects that should be there from the expansion pac, although the new ones don't work. 11R current firmware 1.0.2 have current 1.0.11 drivers. have a slight and growing urge to take a hammer to the 11R, but resisting at present. Have contacted avid supprot, without a reply so far. Is there anything that any of you good people can suggest. Can I load the firmware updater on to a usb stick and transfer to another PC and try running it? Sandra details, hopefully the useful ones?? < Computer > Model: OEM Serial Number: To Be Filled By O.E.M. Chassis: Desktop Mainboard: ASRock H67DE3 BIOS: AMI (OEM) P1.40 02/21/2011 Intel vPro: 7.00.04.1197 Total Memory: 15.73GB DIMM DDR3 < Processors > Processor: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (4C 8T 3.69GHz, 3.7GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot: FC LGA1155 < Chipset > Memory Controller: ASRock Core (Sandy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.33GHz 128-bit, Integrated Graphics < Video System > Monitor/Panel: HSD Generic PnP Monitor (1920x1200, 27.4") Video Adapter: Intel(R) HD Graphics (6 SM4.1 850MHz/1.35GHz, 256MB DDR3 1.33GHz 128-bit, Integrated Graphics) < Graphics Processor > Compute Shader Processor: Intel(R) HD Graphics (6SP 850MHz, 256MB DDR3 1.33GHz 128-bit, Integrated Graphics) < Storage Devices > WDC WD1600AAJS-00M0A0 (160GB, :149GB (C:) (E:) WDC WD5000AAKS-00YGA0 (500.1GB:466GB (F:) SAMSUNG HD204UI (2TB, SATA300,:2TB (H:) (I:) Seagate ST3750330AS (750.2GB,:699GB (J:) Optiarc DVD RW AD-7280S (8.5GB:8GB (D:) < Peripherals > LPC Hub Controller 1: ASRock H67 LPC Controller LPC Legacy Controller 1: T0 C3-33 Audio Device: ASRock Cougar Point High Definition Audio Controller Audio Codec: Realtek Semi High Definition Audio Serial Port(s): 1 Disk Controller: ASRock Cougar Point 4 port SATA IDE Controller Disk Controller: ASRock Cougar Point 2 port SATA IDE Controller USB Controller 1: ASRock Cougar Point USB Enhanced Host Controller #2 USB Controller 2: ASRock Cougar Point USB Enhanced Host Controller #1 USB Controller 3: VIA VIA VT6214L USB UHCI Controller USB Controller 4: VIA VIA VT6214L USB UHCI Controller USB Controller 5: VIA VT6202 USB 2.0 Enhanced Host Controller USB Controller 6: ASRock Etron USB 3.0 Extensible Host Controller FireWire/1394 Controller 1: VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1: Intel ICH SMBus < Printers and Faxes > Printer: Microsoft XPS Document Writer (600x600, Colour) Fax: Microsoft Shared Fax Driver (200x200) Printer: Epson Stylus CX6600 (M) (360x360, USB, Colour) Printer: Adobe PDF Converter (4000x4000, Colour) < Network Services > Network Adapter: Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) < Operating System > Windows System: Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance: x64 < Windows Experience Index > Current System: 5.3 <<< Video Rendering >>> << Direct3D 11 Device(s) >> << Intel(R) HD Graphics (6 SM4.1 850MHz, 256MB DDR3 1.33GHz 128-bit, Integrated Graphics) >> your turn and thanks for helping Marcus |
Re: 11R expansion pack firmware not updating Win7 64
Well I'll be damned,
I have 8 usb slots and I thought what the heck it's midnight and I am fed up with this.... and yes you got it, port 7 of 8 finds new hardware and installs a different looking set of drivers and the update worked. So I now have an up to date 11R with expansion pack and am feeling much better about everything. I am not sure of the technical reasons for this, perhaps some one else can shed some light, especially if it is of use to any others who might be having the same problem. |
A couple things to try.
Install IE8, no need to uninstall every trace of IE, its just IE9 that causes a problem. By the way you can re-install IE9 AFTER you get the 11R updated. Try installing the older driver for the 11R and Windows (1.0.8) then try the update again. Uninstall the old driver first, and be sure to restart before trying to update the 11R. Make sure you are connected to the internet. Make sure Pro Tools is CLOSED. Try another USB port for the 11R. Try another USB cable. Unplug all other USB devices. You CAN update your 11R from any computer, the problem you will run into now is that if you have already typed in your S/N and ID code into the updater, it is now locked to that PC and if you try updating from another PC you will get an error saying the numbers have already been used - even though your 11R has not been updated. Of course if you just can't get the current PC to work, you can call Avid and tell them of your trouble and they may issue you a new code.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I see you figured it out while I was responding.
Hey thanks for the response, yeah got it working now so that is great news, i was starting to think I had made a big mistake!
Can I reinstall IE now that it is all working or are there any on going issues with this and IE? Many thanks |
Only a problem if you need to run the updater again for some reason, but there aren't any known issues with Pro Tools (or the Eleven Rack driver), just the updater app. Thanks.
-Toby Dunn, Avid engineering |
Also the reason I mentioned trying the older driver for windows (1.0.8) is that there is a problem with the 1.0.11 driver and installing firmware 1.0.3 - so as a troubleshooting tip I thought I would mention it to him just in case, you can always switch back to the newer driver with ease. There is also a problem with some rigs not loading from computer when using driver 1.0.11 which I have documented. Glad to see someone from Avid on the board again, don't be a stranger
Thanks Benoni - and thanks for helping out here so much! -Toby |
Eleven rack expansion pack is not updating! | darren051234 | Windows | 0 | 04-30-2012 11:08 PM |
Expansion pack firmware updater crashed | DeanM11R | Eleven Rack | 3 | 03-23-2012 01:03 PM |
Expansion Pack will not update firmware to 2.01 | smartinez5878 | Pro Tools 10 | 1 | 03-03-2012 09:05 AM |
Eleven rack expansion pack install sw not working on win7 64bit !... | KC70 | Eleven Rack | 12 | 02-28-2012 05:46 AM |
RESOLVED: Eleven Rack Expansion Pack Firmware-HELP!!!! | martinaston | Eleven Rack | 3 | 04-03-2011 08:18 AM |
