#171
Re: Pro Tools 9!
A single, recorded audio signal is not better than 20bit, the single channel in TDM is 24bit (which are real and not like the 24bit AD converters), the mixing bus has 48bit. So tell me: Were is a bottle neck in the mixers resolution where the (real) audio signal will be truncated? And, if you do correct gain staging, where is not a pot or a fader to avoid clips? Btw: When do we get the first 32bit floating point AD/DA converters?
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
#172
Re: Pro Tools 9!
I´m sure you know your stuff when it comes to the math involved here.
However I know from firsthand experience that TDM plugs can clip, where the same plug as RTAS will not clip. Even without lighting the clip warning. So real world examples have showed me that the headroom in a rtas enviroment is better than TDM. Regarding recorded levels: I work solely with post, and having proper gain staging on documentaries is not feasible. You woudn´t believe how wildly audio will vary in levels and quality. I try to hammer the levels into a reasonable shape ready for broadcast, but that might mean boosting 24 db or reducing the input on the first plug 6 db just so it won´t clip when adding a LF cut. Bottom line: We need a system that can handle levels way beyond what is optimal gain staging. Not because we don´t know how to operate the gain pot on the microphone amplifier (done by someone "upstream"), we need to be able to work fast and not worry about clipping in the mixbus.
Newest Pro Tools on mac & pc. |
#173
Re: Pro Tools 9!
You can clip a plugin if you´re driving too hot, you can clip the output DA converter but how can you clip the 48bit mixbus?
#174
Re: Pro Tools 9!
A 32 bit floating point mixer has more headroom than 48 bit fixed. But as you keep watching your levels it feels more stable to work with a TDM mixer. Maybe because it is more expensive..I don´t know. I like my TDM stuff.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
#175
Re: Pro Tools 9!
I have no idea why the TDM versions would clip when the RTAS didn´t.
I just know that it happened. And I had reduce the gain by absurd amounts to avoid the clipping. I then switched to RTAS, and the problem was gone. Poof. I have never used TDM plugs if I can avoid it after that.
#176
Re: Pro Tools 9!
TDM are fixed and RTAS are floating point.
#177
Re: Pro Tools 9!
As stated if you know how to drive the TDM system properly some of these things such as clipping can certainly be avoided. However have you tried to open someone else's LE mix session on a HD system & tried to play that back? Quite often there will be clipping going on which wasn't present when played back from LE & you'll soon have to adjust your whole mix again with 'proper' gain staging. This in turn effects compression thresholds down stream etc, etc.
If you take the noise floor of a typical signal, amplify it through EQ, compression, limiting or gain & then lower the level again on the output so the peaks aren't clipping what happens is that the noise floor begins to come up along with all the other garbage that resides there. Do this over multiple channels or multiple passes subjected to 24bit truncation & you'll begin to hear the signal integrity degrade. When you start mixing channels together this can grow the wordlength considerably which is why we have a 48bit summing mixer with a floating 8bit mantissa. Auxillary's are 24bit in so if you're bussing channels to an Aux you need to group all the channels & reduce the level going to it or you run the risk of clipping. If the goal is high RMS levels than this can mean quite a lot of gain stage juggling in a typical HD scenario. Again a lot of this can be avoided without all the 24bit bottle necks. Quote:
Are we done? |
#178
Re: Pro Tools 9!
Everybody who "can" work in TDM is able to do the same Nativ. But not vice versa! So back to my initial question: "You really want a support for "technicians" who are not able to set the correct input level?" BTW: Could you imagine how a recording/mix with a SSL 4000 and a Studer sounds when a guy is engineering who has had nothing but a floating point DAW in his hand ever? Is this what it´s called progress? Edit: My question for 32bit float AD/DA converters was a joke. Sorry for not understanding it.
#179
Re: Pro Tools 9!
In my experience, the 48-bit fixed system of TDM is superior to the 32-bit float engine. Matt is exactly right - the hangup is at plug-in I/O. Once they implement 48-bit throughout the chain, so you have several bits of headroom above 0 dBfs at every point, no more 24-bit dither, it'll be a world-class digital mixer. I bet that's coming.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#180
Re: Pro Tools 9!
To really understand all the technical points above, you need to have worked with an LE system. Otherwise its just a theoretically argument in physics. The same session created in LE will most probably clip a TDM system while it was fine in LE. LE just allowed much higher gain stages prior to clipping which TDM doesn't. Period.
