Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 07-15-2019, 06:50 AM
SvenIsak SvenIsak is offline
Default Can't install EuControl under Mojave
When try to install EUCON_WorkstationUnifiedInstallMac_19_5_1_44 under Mojave, I get a The Installation Failed error.
I seem to recall that I read somewhere that there was a special procedure to install EuControl under Mojave. But I can't remember where and what!
EDIT!
I've done some further testing and all the Unified Installers fail, at the final verification. I had to go back to v3.7 to have an installer that claimed the install was successful. If I try to install a Unified Installer "over" it still fails. This means that I won't be able to install newer versions of the Eucon drivers when they become available.
This is a really serious issue, that needs to be rectified a.s.a.p.!!!
Old 07-16-2019, 09:16 AM
EddieJones's Avatar
Default Re: Can't install EuControl under Mojave
I suspect the issue is with either the downloaded installer or something on your machine (permissions, corrupt drive etc.) Thousands have downloaded this and installed on Mojave so I'm pretty sure it's not the installer.
Can you try to run the Unified installer 19.5.1 and select uninstall All and remove all perfs options and let me know what happens?
Old 07-17-2019, 01:29 AM
I've already done the first part (Uninstall all). I will try removing the prefs when I do the next clean install. I will have to get back to you, at a later date.
On the other hand, it failed when I tried to installed it on a clean install of Mojave. So, there shouldn't have been any preferences files present!
Old 07-18-2019, 05:54 AM
EddieJones's Avatar
If it failed on a clean install then that points to a corrupt installer. Re download it if you haven't already.
Sent from my HMA-L29 using Tapatalk
Old 07-19-2019, 02:42 AM
As I've said, I've downloaded all three Unified installers. They all failed! I had to go all the way back to v3.7 to find one that didn't fail.
Old 07-19-2019, 11:27 AM
EddieJones's Avatar
Strange, I don't think anyone else is seeing this (out of 50000 users) so not sure what to suggest next.
Cannot assign Eucontrol in Security and Privacy on Mojave bobo mark Avid S1, S3, Dock and Control App 3 06-27-2019 07:51 PM
PT 2019.5 + Mojave fresh install: Velvet problem Detlef Brockmann Pro Tools 2019 0 05-18-2019 06:50 AM
Eucontrol and Mojave? Eric Lambert Avid S1, S3, Dock and Control App 3 12-17-2018 02:32 PM
Mojave 10.14 install mspin macOS 6 09-26-2018 08:27 PM
EuControl 3.7... clean install recommended jeffro Technical Alerts 0 10-19-2017 08:51 AM
