Old 09-09-2005, 06:56 PM
PCM PCM is offline
Default Standalone core audio does not work...
powermac g5 dual 1.8, 2.25 gig RAM. os 10.4.2. Pro tools 6.9.2 , stand alone core audio (just downloaded). The old core audio bundled with 6.9 didn't work either. works with Logic but not itunes etc. Same issue with standalone.
ready to kill myself or sell 002r whichever easier. (I haven't had a working core audio driver since I bought this machine a month ago). HELP!
Old 09-09-2005, 07:57 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Standalone core audio does not work...
As it says (in bold letters) on the Tiger CoreAudio page, you should not install this if you already have Pro Tools installed. You'll probably need to uninstall it using the installer, reinstall Pro Tools LE 6.9.2, then download the update for Pro Tools LE 6.9.2cs3 listed on the same page:
http://www.digidesign.com/download/coreaudio/tiger/
Please read the top part of the page carefully.
You will also more than likely need to delete preferences as outlined in the Mac OSX/PT 6 Troubleshooting thread at the top of the PTLE Mac forum.
Administrator
Old 09-09-2005, 07:59 PM
bigsixx bigsixx is offline
i had the same problem when u download the driver or i should say go to the page where you dl it for your version of os it will tell u what systems it works with, see when i had the problem the core for panther did not support the digi001 but i scrolled down to the bottom and they had different versions of the core that eventually after dl worked with my digi hopefully that works for ya
Old 09-09-2005, 08:19 PM
PCM PCM is offline
Hi i did uninstall, but did not delete preferences. will try and will repost.
Old 09-10-2005, 11:39 AM
Beric Clapton Beric Clapton is offline
I have the same problem, I could not run Reason in stand alone mode. When I open Preferences in Reason, theo go to Audio, there is a red cross next to the scoll down menu when I choose Digi as output. I couldn't run Bias Peak and iTune via Digi hardware either? Any solution for this? Thanks in advanced.
My config is G4 dual 1Ghz, 1.75Gb Ram, OSX Panther 10.3 running Protools 6.4.
Standalone Core Audio Driver OSX Lion DGmachine macOS 9 08-10-2011 07:12 AM
Standalone Core Audio Manager? johnnmk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 02-09-2011 09:51 AM
Is there a standalone core audio driver for new imported_tupelohoosier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-13-2006 02:25 PM
6.9.2cs4 Or Standalone Core Audio phobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-07-2005 02:20 PM
standalone core audio driver - when ??? The Lone Roger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 07-26-2003 06:01 AM
